Question about Water Heaters
Hi I have a problem with my valiant combo boiler making aeroplane noises when heating comes on and i turn on the hot water. It's only started doing this so can some body help.
    Problem Solver:
  • 12 Answers
You don't say what model your boiler is but if its one of the older types in my experience its caused by the built in bye-pass and would require changing it to overcome the noise you describe which is what most customers describe. You can prove it by turning the central heating valve of on the flow side of the boiler momentarily you will hear the noise stop then quickly turn it back on, it often helps to you replace with new one.
Posted on May 09, 2015
kma836
  • 7 Answers
SOURCE: boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Posted on Oct 18, 2008
gary1121
  • 332 Answers
SOURCE: Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
Posted on May 30, 2009
gary1121
  • 332 Answers
SOURCE: Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Posted on Jun 10, 2009
  • 150 Answers
SOURCE: Hi there. Our valiant boiler doesn't seem
Lack of pressure in the primary circuit [radiators] Look for a pressure gauge should read between 0.5 & 1.5 bar
Somewhere there is a tap/valve/pipe connection to refill & looks like a small thumb turn or a screwdriver turn on a connection on the mains water inlet pipe. turn on until you get the right pressure then off
Posted on Dec 22, 2009
Testimonial: " Many thanks for your speedy reply. Helpful, although problem not yet solved."
  • 10 Answers
SOURCE: Noisy Hot Water Gushing In Boiler
You may excess air in the lines
Posted on Nov 06, 2012
I got htp boiler combo the boiler make domestic hot water and no heat, termostat good relay good,any parts got be replace.
If you have replaced all parts of the boiler, then there is a water leak somewhere in the system. This applies to flow water heaters. Water does not get warm up then. Perhaps the burner was blown, if you did not check it.
Nov 01, 2017 | Water Water Heaters
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Nov 06, 2012 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Dec 16, 2009 | Water Heaters
May 17, 2009 | Water Heaters
Boiler overheating
good luck!!! tim
Oct 08, 2008 | Water Heaters
Water Heaters Logo
196 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
