Question about LG Televison & Video
Lg model Lgle4500 when turned on will have no audio/vid or light on button display. Only the click of powering on/off. have turn it on/off for several minutes before it starts working properly. ideas?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 15 Answers
Capacitors ...LG is known for blowing capacitors just about the time the warranty runs out. If you can see the capacitors in the lower left / middle, bludged & or black ...they are blown. If you r handy, you can fix it yourself. Pick up a soldering iron & solder (garage sales cheap, this time of year). Mouser Electronics or EBay will have what you need. Take a picture before u start to unplug anything. Pay attention to negative side & the size u remove from board. I have fixed about 5 of these now & it's always the capacitors.
I hope this helps,
Deborah
Lg model Lgle4500 when turned on will have no audi - 25674144-spursr2qhwdobytwih4m3xox-2-0_0.jpg
Posted on May 05, 2015
Adolph
  • 137 Answers
SOURCE: model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Posted on Dec 22, 2007
  • 1039 Answers
SOURCE: Powers off after several minutes
Check and replace swollen capacitors in power board.
Posted on Apr 25, 2009
  • 12 Answers
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
  • 8457 Answers
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
Posted on Sep 14, 2009
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
Lg phone won't turn on. It pulls up the LG logo, after several minutes it makes the start up tone and the blue TracPhone page appears, that's where it stops
You can try a factory reset, I don't know the model, but here is the usual LG reset routine
Ensure the device is powered off.
Press and hold the Volume Down button then press and hold the Power button.
When the System recovery screen is displayed, release both buttons.
From the System recovery screen, select Factory data reset.
Note Utilize the Volume buttons to highlight and the Power button to select.
Select Yes to confirm.
Note Allow several minutes for the reboot process to complete.
Note To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
Sep 22, 2017 | LG Cell Phones
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
LG 37 TV WON'T STAY ON
Try changing the input device to something you are sure, works such as a DVD player. If it is same, there are leaky/dry capacitors and/or dry solders. Please refer it to a qualified service technician.
Aug 02, 2012 | LG 42LC2D 42 in. LCD HDTV
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
Turns off right away
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
rate me!!!
May 24, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Audio stopped working and all but the hd conections dont work
You probably have a bad main board. Go on line, put in your tv name and model number and search for main board.
Sep 21, 2017 | RCA L32WD250 32 in. LCD HDTV
The camera wont turn on
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
Tablet will not turn on
I had the exact same problem. Finally, I pressed all the three buttons, power, left click and right click buttons and held it for several seconds. After that, the tablet turned on.
May 21, 2008 | Wacom Graphire A5 (CTE630BT) Graphic...
Televison & Video Logo
51 people viewed this question
Computer Repairing
Computer Repairing
