Question about Car Audio & Video
RCA port snapped off,
Could I purchase a new RCA port and solder it back in?
  • 3,904 Answers
Yes you can. Allied electronics is where you could get the replacement or a Radio Shack if you have one by you.
Posted on Jun 03, 2015
Replacing the RCA port on a car amplifier?
Of course it is possible also if that does not work you can take an aid out I'm sure 11_29_2015_7_39_27_pm.png
May 01, 2015 | Car Audio & Video
Hi, the battery cable end that connects to the hummer broke. The wires snapped due to the kids pulling it apart. Can I solder it back on or do I need to buy a whole new cable. Just replaced the...
You can probably go on amazon.com and purchase another cable far less than what the stores charge. There is a chance if you solder the wires back together that it can blow the charger completely. Cutting corners is fun, but not when it comes to electronics.
Oct 14, 2013 | National Little Tikes Hummer Yellow
REEPLCE ANTENNA INPUT ON D52W19 RCA PROJECTION TV
Often they can be soldered back onto the tuner. But the tuner itself may need replacement which you can get tuners and the entire SSB which has the tuners already on them from www.tvrepairworld.com
Dec 18, 2011 | RCA D52W19 52" Rear Projection Television
Amp comes on but music plays for 30 seconds then crazy feed back noise.one of rca jacks feels loose are they replaceable
Yes they are can be replaced. If you meant the RCA female sockets on the amp then it needs that the amp is taken out and the RCA terminals soldered -- it can be poor joints. If not you can de-solder and change with a new one.
If this is the RCA main socket then the wire can be **** off and a new RCA jack of good quality can be soldered, taking care to keep the shield and main line with a good solder point.
Feb 05, 2011 | Phoenix Gold Tantrum 600.4 Car Audio...
Imput 2 has lost one color on my Hitachi 51F510 HDTV
If you broke the RCA connector you can purchase another at Radio Shack or similar electronic store.Remove the back cover and replace the connector
Sep 16, 2009 | Hitachi 51F510 51" Rear Projection...
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
Repairing RCA Opal M4002 player?
I had the same problem. my m4002a wouldn't charge or anything. So I decided to take it apart to see what I could see. There are four solder points on the headphone/charge jack that are soldered to the ic main board. Two of my solder points were cracked, so I just melted the solder and bingo it works fine now. I added a bit of highstrength hot glue to the port so it wouldn't move anymore. That seems to have done the trick. I am guessing by maneuvering your headphone jack you are actually causing the solder points to make contact with the ic board. Of course you may not have the exact problem I had but it could be worth a shot.
Nov 03, 2008 | RCA M4002 Digital Media Player
Rca ctc195 big screen tv trouble
You are likely to have a high voltage transformer bad which is common problem for ctc 195 RCA If you look into the back of the tv it is the white square looking thing about 3 inches across by 3 inches with the large red wire coming from it and going back into the set. Must have original RCA part and must be unsoldered and solder in new one. Not to be done by the untrained. Average cost to come out and repair is $250 to $300. depending on the repairman (Note: the chassis is in a complete wooded chipcore box that will come out with quarter inch nutdriver and unplug two plugs at the top of the box The box or chassis can be taken to the repair shop leaving the screen at your home saving a service call. Hope this helps
Dec 30, 2007 | RCA P52937 52" Rear Projection Television
Car Audio & Video Logo
107 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
