Question about Craftsman Air Tools & Compressors
Does anyone know how to load nails in a craftsman stapler/nailer
There are no directions on how to use the nailer.
  • 1388 Answers
SOURCE: CRAFTSMAN NAILER
Generally, if your nailer is not leaking air, the orings are probably ok. Remove the head and check for stuck headvalve or stuck driver/piston. Make sure that you can press the headvalve into the head with your thumb and that it returns. If your driver/piston is down when you pull the head, remove the cylinder and check for damage to it or the bumper. Some cylinders have an oring or strip of rubber about med section which acts as a check valve causing the piston to return to top. Check for bent driver or broken tip causing driver to jamb. Use silicone lube to assemble. Enjoy
Posted on Dec 08, 2008
rowdy45176
  • 2176 Answers
SOURCE: I need a manual for my 18 ga combination nailer/stapler kit
What you can do is go to the Sears.com website and under tools it will lead you to Sears Parts Direct and (bottom of page) when you get there there is a block for manuals type in the model number and you can view it online or get one. Hope this helps Dave
Posted on Dec 21, 2008
  • 1388 Answers
SOURCE: D51844 Won't Fire Nails
The Dewalt D51844 uses a full round head 20 degree nail. Sometimes the generic brand nails are not made exactly to the stated degree. They do this so their nails will work on a variety of nailers. Best to check the nails angle in relation to the angle of your nailer. Place a strip of nails on the outside of the rail. Align the heads of the nails to a convenient straight edge on the rail then check that the head and shaft of the first nail is aligned with the barrel. If the lower part of the nail projects out further than the head, then the driver will miss the head. If the head of the first nail appears close enough to barrell for the driver to hit it then place a new strip of nails into the mag and slide the pusher foward. Fire one nail, if success, remove the nails from the mag and check if the plastic holding the nails together is projecting in front of the first nail. Sometimes the plastic is not right, too stiff, and will not let the next nail align with the barrell. If the next nail appears ready and slides forward then the driver may not be going all the way up after shot. Check by inserting a metal rod into barrell and push driver up till it stops. If the driver is in the uppermost position, then most likely brand of nails. Use Dewalt nail. Good Luck
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
get a senco
Posted on Mar 11, 2009
  • 8 Answers
SOURCE: my mastercraft electric brad nailer stapler wont
Look for a jam in the gun.Sounds like a brad is "hung up" in it, probably right at point where it feeds into the mouth of the firing point. Be sure you unplug it before you do this.
Posted on Jan 15, 2010
How do you load the brads.
Depends on the Type of Brad nailer & Model No. Gimmie that info please?
Nov 29, 2017 | Tools & Hardware - Others
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I fix my craftsman electric brad nailer
I have one that looks just like the illustration and mine doesn't operate either. I have had it apart and the switch is faulty and seems to be a very poor design.
Mine has a different brand name (Rapesco) and under the label is a generic Chinese export which the local supplier reckons is a throw-away item and no spares are available.
One of these days I will exercise some guile and attempt a repair.
Feb 02, 2015 | Craftsman Electric Brad Nailer
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
The nailers piston that drives the nails is cracked onley drives nails half way in
im afraid that if the piston is cracked, then you have to replace it ( since you know that it is cracked then ill assume that you know how to remove and replace it) you can buy one at your local nail store or you can try toolpartsdirect.com,,, please rate this ,, tks
Dec 15, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
I have bought a tacwise 140EL nailer/stapler. I
Turn the gun upside down and pull out the black plastic loading thingy, drop the nails in the left hand side of the gun,press against side with finger and slide black loading bit back over top of nails-hey presto!
Oct 13, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
168 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
