Question about Refrigerators
Fridge leaking water and noisy fan in freezer
  • Refrigerators Master
  • 473 Answers
I'm going to guess this refrigerator has an icemaker in the freezer. The water leak may be from the ice maker filling process. If that is correct, the water sometimes gets behind the freezer back wall and re-freezes around or near the fan blades causing the noise. Just a guess with out a brand name and model number.
Posted on May 01, 2015
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
Fridge/freezer Samsung3116NW very noisy from left fridge wall Ithink
if the left side of your fridge is the freezer compartment , chances are you have a bad circulation fan . I would suggest replacing the fan motor assembly . The circulation fan is located at the rear of the freezer mounted to the evaporator cover .
Feb 19, 2011 | Samsung Refrigerators
Sde by side refrigerator. fridge icing up and fan very noisy
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Samsung RS2630SH Side by Side Refrigerator
E440t water pooling inside roof of fridge. then it leaks into fridge when its full. fan was noisy, now not making much noise. maybe its stopped.
THE drain in freezer is frozen over and the water is leaking into the fresh food / clean drain with hot water and turkey baster . this wil correct problem . some units need a drain heater installed to prevent it from doing it again .. mm
Aug 11, 2010 | Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
