Question about Maytag Washing Machines
Display error code np
Washer will not spin
  • tom cassidy
    tom cassidy May 01, 2015
    Hi Roxanne Cruz, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Greg Hoffman
    Greg Hoffman Jul 02, 2015
    Need model number top load front load
    Top Expert:
  • Maytag Master
  • 74,211 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 02, 2015
2 Suggested Answers
SOURCE: how do i get codes for a whirlpool cabrio wtw5500xw0 washer with no display?
Error codes for WTW5550XW whirlpool cabrio
It would appear that no one read your original post, I believe you asked: HOW DO IT GET THE ERROR CODE. I have the same machine and had the same problem. The method is descibed in the service manual available at servicemanuals.net for about $17. It also has a decent wiring diagram and how to generally do anything the local service guy could do well worth the money for a download you can have in your hands in minutes.
Back to your question.1) turn the washer off (the power button) all the indicator lights should be off.
(now think of your old gym locker combination lock, cause it will be a little like this)
2a) rotate the center selector knob CCW (counter clockwise a few clicks), this seems to get the machines attention
2b) immediately rotate 1 click CW clockwise
2c) immediately rotate 1 click CW (again)
2d) immediately rotate 1 click CW (again)
2e) immediately rotate 1 click CCW
2f) immediately rotate 1 click CW (again)
visually it would look like this <---,->,->,->,<-,->
now just the led's below the indicator should be blinking off and on on about 1 second intervals
you may need to try a few times to get the timing just right, you aren't spining through the clicks, just about enough time to say "left-left-left-right one,right-two,right three,left one, right one
with all the led's in a row blinking you are ready to go into code mode.
(sensing soak wash rinse spin done) (mine doesn't have soak BTW)
3) rotate the selector knob a few clicks until only the "done" led is lit
4) press start
5) the led's should blink again
which leds blink tells you alternately the fault# and error# when the "sensing" led is blinking, the other leds are indicating the fault number, when it is not on, the indicate the error# the fault# is the type of problem, and the error# indicates where the problem was detected.
6) a partial listing using the fault #, I will indicate the led as follows: Sensing/Wash/Rinse/Spin/Done
S/W/R/S/D this would be all these leds lit
s/w/r/s/d this would be all these leds off
the F# codes to the right is what you would see if you had the numeric display on the console (not all models)
Here goes:
Over suds condition: S/w/r/s/d F0
High water temp rinse cycle: S/w/r/s/d F0
Off balance load: S/w/r/s/d F0
Main control fault: S/w/r/s/D F1
Motor control fault: S/w/r/s/D F1
Stuck key: S/w/r/S/d F2
Mismatch of main control UI: S/w/r/S/d F2
Pressure sensor fault: S/w/r/S/D F3
Inlet water temp fault: S/w/r/S/D F3
Lid switch fault: S/w/R/s/D F5
Lid lock fault: S/w/R/s/D F5
Lid unlock fault: S/w/R/s/D F5
Lid not opened between cycles: S/w/R/s/D F5
Basket speed sensor fault: S/w/R/S/D F7
Shifter fault: S/w/R/S/D F7
Motor fault: S/w/R/S/D F7
Motor unable to reach target rpm:S/w/R/S/D F7
No fill long fill: S/W/r/s/d F8
Overflow: S/W/r/s/d F8
Hot cold reversed: S/W/r/s/d F8
Long drain: S/W/r/s/D F9
yes several of these had identical blinking light combinations, but it is good start.
Posted on Dec 04, 2012
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Getting E360
Hello wdquintana - Are you certain the error code is E360? This manufacturer does not have any E360 error code for any front load washer or other units. They do have error code EB3, EF6 or EA3 however. I understand that it spins fine, however shuts off a few second later. In this case the washer could be experiencing a communication error with the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to see if it will display another error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Dec 07, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frfw3700lw0 drains but not spinning
Hello ctilton2001 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 06, 2012 | Frigidaire FRFW3700LW Washer
Washer says f26 and won`t spin the clothes out. is there anything i can do?
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl topload washer
You are going to have to pull the front cover off the machine and do an inspection for that water leak here is some support info.
The Service Manual for reference. Sears Parts Direct for reference.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the SM
About the “OF” alarm if it’s a valid error code it seems to be undocumented. Let me run this by you. I wonder if it could be something like valid “OP” error code with a bad segment of the second portion of the LED display. If your FAV6800AW would allow you to enter a Spin Only cycle the display would read “10” min for the countdown timer at the start of that cycle. Can you put the washer in a Spin Only cycle and see if the console display indicates “10”? You can then cancel the spin only cycle.
How did you make out with your previous “OD” error?
Rich
Jun 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and the meaning...
Dec 15, 2008 | Frigidaire Washing Machines
E065 error
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Jan 15, 2008 | Canon NP 6035 Copier
Washing Machines Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
