Question about Dremel Tools & Hardware - Others
I switched it on and then off. The light has stayed on? It wont switch back on.
5 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: switch is broke for light in my ge side by side refrigerator
Hi, what you will have to do if you are inclined to do so, is to unplug the appliance. The light switch has only one wire connected to one side of switch and out the other side. Just grab hold of switch gently with pliers and a small rag between the jaws and pull it out and move it back and forth to pull it out. Get the model and serial number and go to you're nearest appliance parts store and get a replacement switch. After you remove the switch, tape up the ends of the wires and push them out of the way of the door closing, so you can plug it back in until you get the switch. Very easy for you to solve. Good Luck,
Shastalaker7
Posted on Jan 24, 2010
  • 884 Answers
SOURCE: freezer wont switch off
Needs new thermostat. If trying to switch off and compressor still running, contacts stuck together. Many freezers run like this for years!
Posted on May 07, 2012
  • 457 Answers
SOURCE: ignition switch light stays on sometimes wont start car on a 89 celica
anti theft is going out.
Posted on Aug 04, 2012
bduxbury
  • 3497 Answers
SOURCE: Wifi wont stay on it switches back off or wont even switch on
aeroplane mode may be on
Posted on Mar 20, 2016
No turn signals. hazard lights work only when button is held in. Hazzards will not stay on. Is problem in turn sig switch or hazard light switch
If hazard switch wont stay engaged and the turn signals run through it I would replace hazard switch then retest
Apr 11, 2015 | Cars & Trucks
Signal handle wont snap back after making a turn
You will basically have to replace the cancel cam to correct this problem. Some disassembly of the steering wheel components may be required and if the vehicle is equipped with air bags it is probably better left to a professional.
Apr 13, 2014 | Chevrolet Lumina Cars & Trucks
Over head lamps wont turn off
Have you checked the roller switch next to the headlamp switch? If it is rolled all the way up, then the lights will stay on all the time. Try rolling the switch back down, you should feel a "click" inside the switch then the lights will shut off. This switch also controls the brightness of you instrument cluster lights. Hope this helps.
Nov 17, 2013 | 1997 Ford F150 Regular Cab
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
My back brake lights wont turn off they stay on
only one course of action here and thats to replace the brake light switch
Feb 12, 2011 | 1988 Oldsmobile Cutlass Supreme
My 1995 Chevy Tahoe brake light switch wont stay in position and the brake lights stay on. I replaced the switch and had the same problem.
Brake Light Switch REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disable the SIR system (if equipped).
  3. Remove the clip (R/V Series) or unclip the switch (C/K Series) and unplug the electrical connector from the brake light switch.
  4. Remove the switch.
  5. Installation is the reverse of removal.
Oct 07, 2010 | 1995 Chevrolet Tahoe
Switch is broke for light in my ge side by side refrigerator
Shastalaker7
Jan 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
91 honda accord brake lights stay on replaced
are you sure you the adjustment to it is correct the button in the end of the switch has to be fully depressed to deactivate the circuit
Jan 19, 2010 | 1991 Honda Accord
Head lights wont turn off after turnning off car
See if you have fuse under dash or under hood if more fuses in there that is marked DRL , or DRL module. (daytime running light module) may be at fault. Pulling that fuse may isolate problem, otherwise you may have to pull connector off back of light switch to test it.
Jun 06, 2009 | 1995 Dodge Spirit
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Tools & Hardware - Others Logo
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
