Front load washer fills with water when door is open
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Door inter lock fault replace same
Posted on May 01, 2015
Duet front load - water fills while door is open!
This is a leaking solonoid valve.
The valves are located just inside the machine where the water supply hoses attach.
  • Remove the power plug
  • Undo the top lid of the washer
  • The valves will have some internal pipes clamped on their outlets. Remove the pipes.
  • Dry the valve outlets with tissue.
  • Turn on the water supply to the washer (if it was off)
  • Watch the open valve outlets for seepage.
There may be between 1 and 3 valves depending on the model.
You should be able to replace the leaking valve quite easily.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
What could be causing my washer to fill with water when off and not in use?
Either you have a short somewhere or a ghost messing with you. I'd call the repair man before the priest.
Jan 06, 2014 | KitchenAid KHWS01PMT Front Load Washer
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
Washer filling with water when off
sounds like a bad fill valve...contact HHGregg. This is a warranty issue. Do not attempt to make any repairs, it would void your warranty and then you would have to bear the repair costs.
clarkco
Feb 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
