Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
I have a desktop PC with a DSL broadband connection. Broadband modem is a standard modem (without Wi-Fi) having only 1 Ethernet port. I wish to access Wi-Fi internet in my home. I have also a spare DSL modem -with Wi-Fi (not router) having 4 Ethernet port. My Wi-Fi modem can also be configured directly to solve this purpose. So, I tried to configure it myself. DSL link on Wi-Fi modem shows stable but I could not access internet. I talked to Internet people they told, "MAC is need to be configured" which confuses me. Is it possible to connect my both modems and PC together with an 'Ethernet splitter' to access internet while using my standard modem as primary and Wi-Fi modem as secondary, just to broadcast Wi-Fi signals. Please guide me, is it possible to do? Thanks!
  • Manpreet Verma
    Manpreet Verma May 06, 2015
    Hi Geekymark!
    Thank you very much for your reply. Really, it works!!!
    I have done all the setting which you described. IP of Non-WiFi modem and IP of Wi-Fi modem was same 192.168.1.1 so, i changed the IP of Wi-Fi modem to 192.168.0.5 and disabled the DHCP.
    Now Wi-Fi modem broadcast the signals but speed is slow.
    Secondly, I could not access my Wi-fi modem by 192.168.0.5 or 192.168.1.1. Browser shows "Page cannot be displayed" message.
    Please guide me...
  • geekymark May 23, 2015
    Why the different addresses? Put both devices in the same subnet. Whatever address you give to the wifi modem must be removed from the DHCP pool. Once you place both devices in the same subnet the wifi speed will increase.
  • 7 Answers
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
Posted on May 05, 2015
  • Manpreet Verma
    Hi Geekymark!
    Please guide me...
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
How to hook up earthlink dsl
can you connect screen I see in right side of your photo to vga output on laptop and use FN + F5 to switch windows output to secondary VGA device. IPad should connect to Wi Fi but not to Laptop.
Is the router wi fi if it is not plug laptop into ethernet port via cat5 ethernet cable . Do you have a DSL modem you need one to hook up DSL and then Ethernet cable to Router. Also DSL filters are needed on Phones or faxes .
Apr 19, 2014 | Computers & Internet
How to use switch?? this is the topology INTERNET->MODEM->ROUTER AS AP ->...
Switch learns network MAC addresses And controls the network packets to reduce broadcast packet traffic on your network !
INTERNET V MODEM V Back of router ethernet port 1 V ROUTER AS AP Wi Fi Back of router ethernet port 2 V Switch Port V V
-> STATION Client/ /CLIENT ' Local/Lan
or
INTERNET V MODEM V Could Place Switch in Here instead Switch Port V V V ROUTER Station V AS AP Wi Fi client V V Client/ Local/Lan
May 03, 2017 | TP-LINK TL-SF 1008 P 8-port 10/100 PoE...
I HAAAAAVE A AT@T WESTELL MODEN BUT MY COMPUTER IS NOT WIRELESS BUT I HAVE WIFI ON MY ACCOUNT. I AM THINKING ABOUT GETTING A SYLVANIA NETBOOK WHICH IS WIRELESS. WILL IT WORK IN MY HOME . THANK YOU
Let me clear up a little confusion. You don't have wi-fi on your account, you have Internet access. Wi-fi is not something that you subscribe to or purchase separately. Wi-fi (wireless) access is provided by a router that allows the Internet connection you pay for to be shared by several computers. The typical router has both wired connections (usually 4 of them) for computers that don't have wireless capability, and acts as the access point for your wireless network.
Your modem is the device that connects you to the Internet through your service provider (ISP). Most ISPs are supplying a combination modem/router for their customers since so many people want wireless access in their homes. If you have one of these, you actually have wireless capability already. But your modem might be an older type, supplying a single wired connection for one computer only. You didn't give the model number of your Westell modem so I can't tell you what you have, but you can tell by looking at it.
A single-connection DSL modem will have only two ports. One is the connection to the DSL phone line, and is a standard-size phone jack labeled "DSL". The other is the network cable connection to your computer, usually labeled "COMPUTER", "LAN" (short for Local Area Network), or "ETHERNET" which is the type of cable used. If this describes your modem, you will need to provide your own wireless router to make your new wireless netbook work.
On the other hand, a combination modem/router will have the DSL connection jack and 4 connectors for computers. It may also have an antenna for the wireless function, but some newer models have internal antennas. If you have one of these, you already have wi-fi capability. You will probably need to set up your network so that your netbook can use it.
There is plenty of information available about how to install a wireless router if you don't have one already. In fact, almost every one now comes with an installation CD that will guide you through all the steps. They aren't expensive and are for sale almost everywhere that sells electronics (office places, Radio Shack, retailers like Wal-Mart, etc.). If you already have the combination device, you can call your ISP customer service for help in setting up your network, or find the information on their website.
So yes, the Sylvania netbook will work in your home, although you may need to do a little work first. But it's really pretty simple, and you'll have that computer online without wires in no time.
Mar 24, 2011 | AT&T High Speed DSL Modem
How to get ethernet
ethernet which is 10/100 mbs is LAN provided out of the four ports. The wireless is not ethernet it is WI FI. Router will give IP addresses in DHCP format automatically to 190 peripherals. There is no getting ethernet, it is supplied.
Feb 04, 2011 | Arris 3347 DSL 4-Port Wireless Modem -...
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
Hello. I bought this modem with wi fi ,dsl router. How to set it to use this modem as a router.I want to connect my pc with lan cord & use wifi connection with my laptop and phones.
Turn DSL-router off.
Turn Actiontec off.
Turn computer off.
Connect:
* telephone-port in wall <--- 4-pin telephone wire --> DSL router
* Ethernet port on DSL-router <-- Ethernet cable --> WAN port on router
* One of the LAN ports on router <-- Ethernet cable --> network-port on your computer.
Turn DSL-router on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn Actiontec on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn computer on, and boot it.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you saw)
Login to your router
Configure the wireless adapter inside the router
(enter an SSID, choose 'WPA' encryption, enter a password)
Disconnect the Ethernet cable from your computer
Click "View Available Wireless Networks",
and select the SSID that you provided.
Enter the password that you provided.
Oct 21, 2010 | Actiontec GT701WG Router (actiongt701wg)
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
How to connect my router without the phone line
since you have a wireless router... you can turn on your wireless connection..try to reinstall it..and proceed to the admin page and turn your wi-fi there...then put password so that you can secure your connection..
after that your computer must have a usb bluetooth device.. you can ask for it in the market...just ask for your purpose...
note: connection of your wi-fi in your computer depends on what is the capacity of the bluetooth device you will buy... i mean it has it's limit in size in transmitting and receiving data...
Feb 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
498 people viewed this question
David Payne
David Payne
