HOW COME WHEN I INSERT MY DVD IT IS REJECTED
Everytime i slide an dvd in the tv,i get a delete pessage or the dvd wont take.the movie will not play and there is a clicking sound when the dvd is inside thet tv
  • 3,320 Answers
The DVD is in a format that the player cannot read. You could check what formats your player supports. If it is a writable CD your player may not support that particular format. If other discs play then the fault is obviously with the one that wont.
Posted on May 01, 2015
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
Make movie disc ejects before
It sounds to me like the DVD ROM in your computer has the problem playing it's DVDs, so what happens when you play it in another Computer with it's DVD ROM?
Aug 10, 2008 | Pinnacle Televison & Video
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
I have an Orien FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
When i put a cd in my cd/dvd rom it wont play dvd movies nor cd's, it wont show the dvd movie in windows media player nor itunes nor quickplay. the rom says dvd rw-r and those are the dvds i play and...
Try to run the following hyperlink
Hyperlink to microsoft automatic assistance
Hyperlink to Cd drive autofix
If it doesnt work then try following steps:
  1. loadTOCNode(2, 'resolution'); Click Start, and then click Run. (in case of windows 7 click start, look for search program and files , type in there regedit and hit ok, jump to step 3)
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  1. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click
    UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  2. On the Edit menu, click Delete.
  3. When you are prompted to confirm the deletion, click Yes.
  4. In the right pane, click LowerFilters. (dont panic if you dont see lower filter)
    On the
    Edit menu, click Delete. (or simply right click and select delete)
  5. When you are prompted to confirm the deletion, click Yes.
  6. Exit Registry Editor.
  7. Restart the computer
Apr 20, 2011 | HP DVD DRIVE DVD Drive
Everytime I start the TV I get a no signal, also can't get the DVD to play? Model #PLV7122 TV/DVD, 22"
Make sure you are on the correct input. Usually there is a input or source button on the TV remote. Put a DVD in and hit the play button on the front of the DVD player so you can see the movie when you know you got it right.
Sep 13, 2010 | Venturer Televison & Video
Sony tv will play copies of movies from tv, but won't play store bought new ones. I mean current popular ones. It played Avatar last week but won't now. We tried several new movies and none will play. Put...
There is some confusion in the explanation here.
The TV does not play movies it displays them It is the DVD that Plays them. But of course you knew that. Some of the newer movies like avatarcan be on Blu ray if your DVD is supposed to play Blu ray but doesn't don't be surprised as they have changed the format recently. Your DVD will require an udate of firmnware. Go to the website of the DVD brand and contact support Download the update and burn it to a disc and run it.
With the TV end Make sure the resolution can be accepted from the DVD you are trying to Play. If it isn't HD or capable of 1024x768 at 16.4 then it may not be able to display the image. Is there any sound?
If sound but no Pic then start playing with the picture format. go to 8.2 or 4,0 to see if it makes any difference
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Televison & Video
I have a Sony Handycam Vision CCD-TRV65 and want to convert my tapes to DVD. What device to I need to do this?
well this is what i do and it is pretty long and not a really good way so first connect one side of your av cable to the output of your tv and the input to your camcorder and with the help of another av cable put the input to a dvd recorder and the output to the input of your tv then insert a (dvd+r/dvd-r) dvd into your DVD Recorder then record the video that is displayed on your tv to the dvd inserted into the dvd recorder then finalize it when it finishes and put it into your computer
So Basically all i use (as the device) is the DVD Recorder which u can find in any electronic store or online or on ebay i use this to record tv any video and videos on my camcorder and movies that i insert onto my usb and play it on my Nbox or Ps3 and then i record/burn the movies onto a dvd-r/dvd+r
Ps. I Say dvd-R is better because you can format it and delete titles and videos from it but u cant do this on a DVD+R
Feb 11, 2010 | Sony Handycam CCD-TRV87 Camcorder
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
