Question about Next 24" PX 4.0 Boys Mountain Bike, Black
Next 4.0 boys mountain bike rear wheel assembbly
Putting rear wheel back on
Need to find a new seat/replacement post for 24" Next PX 4.0 Boys Mountain Bike, Black
I am a privet bike repair shop the seat post is a 25.4 mm 9 inch log i have a used seat post in stock and a new seat in stock that will work with a next px 4.0 a had the same issue you contact me on my web site
May 08, 2015 | Next 24" PX 4.0 Boys Mountain Bike, Black
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
When i shift to 2nd gear and let off it shifts back on its own
Travis:
Put the rear derailleur into second gear and stop the bike before it shifts back down. Look carefully at the derailleur and you will see two small screws next to each other. These are stop screws. The stop screw for high gear may be out of adjustment, or the front derailleur is out of alignment putting sideways torsion on the chain forcing the chain to drop back into first gear.
May 04, 2014 | Mongoose Maneuver Mountain Bike
I have (2003-2005 ?) year model Schwinn Sierra GSX 26" mountain bike. I need a diagram that shows how to route the chain. I had to remove the back tire. Now I can't get the chain to line-up on...
Basically, shift the rear derailleur to the highest (smallest) gear before removing/installing the wheel.
Google "how to replace rear wheel on a bike" for video advice.
Jun 18, 2011 | Schwinn 26in Men's Drifter Cruiser Bike
How do i change the rear tire on 2003 harley fatboy
Get the bike up off the ground, just slightly at first. Then take the nut off the axle. If your axle is inserted into the swing arm from the left side, start to withdraw the axle. If it's inserted from the right side, you'll probably have to remove the muffler(s). As you pull the axle out, remove and mark any spacers that come out. Mark where they go and in what direction they were facing. If you have difficulty getting the axle out, you may have to loosen the wheel adjusters on either side of the swingarm.
Once you have the axle out and the wheel sitting on the ground, start raising the bike more. As you come up with it, work the drive belt off of the pulley. You may have to remove the lower belt guard to do this. Do not twist the belt or squeeze it in a radius sharper than 4 inches or you will damage the belt. When you get the bike raised enough so that the rotor is clear of the caliper, start leaning eh wheel over and working it out from under the bike.
Seems like there are three spacers on a Fat Boy. Two are very short and go into the bearing seals on either side of the wheel, and one is a longer spacer that goes on the belt side. The spacer on the other side is the brake caliper bracket. Make yourself a drawing. Invaribly, you'll look at a spacer and wonder "did it go here or here". Drawings never lie.
When you put the axle back in, insert it from the left side of the bike. That way, next time you won't have to take the exhaust system apart. To adjust the belt, first get both wheel adjusters to the same length. The turn them each the same amount at a time moving the wheel backwards in increments. Once you get the belt tensioned correctly, the two adjusters should be the same lenght. This gets the rear wheel aligned correctly in the swingarm.
Check the operation of your rear brakes before you ride the bike. If you start hearing a "chirp" when you shift gears on the bike, your rear belt is too loose.
Good Luck
Steve
Aug 18, 2010 | 2003 Harley Davidson FLSTF Fat boy
Trying to reassemble rear wheel gear assembly for huffy mountain bike. i didn't take it apart and don't have a manual. someone else took it apart
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Aug 29, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
The cassette or hub "clunks" on my mountain bike
it sounds like the barrings your going to have to bring it to a shop or buy a new wheel
May 03, 2009 | Sram 850 8 Speed Cassette 11-32t Mountain...
Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Next 24" PX 4.0 Boys Mountain Bike, Black Logo
467 people viewed this question
Top Next Cycling Experts
downhille
Ted Maxwell
Jerry Kramer
Jerry Kramer
Are you a Next Cycling Expert? Answer questions, earn points and help others
