Question about Kenmore 83042 Electric Dryer
Need to open the top of the dryer to change the heating element. How does it come open?
Got two hot in two cycle and then quit heating. need to open top.
  • Kenmore Master
  • 473 Answers
Model number isn't complete---doesn't come up on sears site for me to look at the breakdown. Recheck number and re-post and I'll try to help
Posted on May 01, 2015
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
Why is the outside top so hot to touch. It is 2 weeks old and Vents were cleaned before using.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 30, 2015 | Hotpoint Hot Point HTDX100EMWW Electric...
The top right side and the right side of the get very hot when drying clothes
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 26, 2015 | Dryers
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 16, 2014 | Asko Dryers
Why is dryer over heating after changing 3 prong to 4.?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 04, 2014 | Hotpoint Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
Top of dryer and top rear panel gets very hot to the touch
yes,check the hi-limit switch on the case of the element housing,it will have 2 heavy wires attached to it and it probably isn't opening up to let the heat element cycle,also check the heat cycling switch in the unit also this can be in the exhaust vent or numerous places to moniter heat for drying clothes
Nov 19, 2009 | Cell Phones
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 83042 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
