Question about Garden
Used it last year.This year the chord to the extension chord frayed in two places.From the handle.And where the outside extension chord connects
  • Garden Master
  • 2,540 Answers
I take the old wires out and replace them An electrical shop should have the cord you need. The switch on the handle should come apart and go back together again Just becareful you put it back together the same as you took it apart.
Posted on Jan 04, 2016
DC14 arm extension will not lock in place.
I WOULD CALL DYSON TO BRING IT IN THEY CHECK IT FOR FREE FOR YOU, AND WARRANTY IS USALLY 5 YEARS FROM PURCHASE.
https://www.dyson.com/support/warrantyterms.aspx
http://www.dyson.com/support/servicecenters.aspx
May 25, 2016 | Dyson DC14 All Floors Upright Vacuum...
Have a mity mite ps 120 a automotive jump starter but no chord to charge it. can i just use any chord or do i need to buy a replacement chord? And if so where can i purchase?
What Cord?
Your asking about plugging it into the homes
electrical outlet ?
Can't use just any cord,not a two prong lamp cord
type extension,no
You use a three prong grounded extension wire
Does it not have several feet of wire on it & a three
prong plug?
You use a standard outdoor extension, like you
would for a vacuum cleaner outside
If you use it a lot, buy a short 6 foot one,just to
use with it
How about the owners manual ?
Nov 25, 2014 | Cars & Trucks
1998 Isuzu Rodeo Drivers Outside Door Handle doesn't work
The door skin needs to be removed you will need 1/4" drive ratchet, extensions, metric box end wrenches, a long needle nose pliers, screw drivers,a pro pick set and some mechanical ability, verify the linkage is intact, if it is you probably have a broken handle, if the outer handle is broke E-Bay has them new and used or you can go the dealer route. the time to repair is usually 1 to 2 hours. GL
Aug 18, 2012 | 1998 Isuzu Rodeo
Hp c5280 wont switch on, its been working well when last used this morning.
Disconnect the power chord from the back of the printer. Wait for 40 seconds and connect it back and check if it is warming up or not. If not the press power key for few seconds and see if it turns on or not.
If not then check if the adapter is getting warm or not after it is connected to wall outlet.
If adapter is warming up then try another power chord and check..
If both power supply are getting warmer then problem is with printer hardware and if printer works with another power chord then replace the damaged power chord
Feb 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
Ront pane audio
Sorry but that is not possible internally. From the rear panel, plug in an extension chord and use the extn in front. Use a shielded cable to eliminate disturbances......................sodeep
Nov 10, 2009 | Computers & Internet
Vista 390 Extension in Use problem
I had this exact same problem. First to thing to check is that all other equipment is functioning; it is possible that the receiver on a fax machine has been knocked off its cradle.
Also the wires at your jack should be tested.
It was intermittent. It took a few years, but we finally connected the fact that this only happened after there had been considerable rainfall outside. (... I know!) The Bell repairman was able to determine from outside that the problem was not inside; he had me disconnect each and every piece of equipment and he checked the strength of the signal after each one was removed.
Then he told us the truth; our line was strung up as a 'temporary' line back in 1985!! Bell was replacing trunk lines on city streets to improve a decaying infrastructure and would have replaced all temporary and fraying wires as each street was upgraded. But - according to the repairman who has been with Bell for decades - Bell stopped the upgrade projects in favour of putting the funds into competing with Rogers and the internet. Their philosophy since then has been to make temporary repairs to provide a phone connection no matter how bad, and regardless of how many times they have to make service calls. There are literally tens of thousands of customers who are receiving bad service out there, because a) their main line has been 'temporarily' spliced into a neighbour's existing line, even tho' they all pay full service rates!, and .... b) thousands of street-long trunk lines have frays in them that short out in the rain, scrambling service for everyone along that line, to some degree, but there is currently no one working on system upgrades. There would have to be literally scores of complaints along a particular street for Bell to even think of upgrading the trunkline.
As soon as we had a permanent phone line installed, the 'extension in use' problem stopped.
So please have the outside wires checked out and ask the repairman questions about the condition of the actual lines.
May 05, 2009 | Aastra Telecom Powertouch/Vista 390 Corded...
Since my last time i used garmin nuvi 260 it cant find a signal
Try going outside with a clear veiw of the sky, since it cant aquire a satellite its simulating the last place where you were. Try canceling the route and see if it connects with the satellite.
Jan 08, 2009 | Garmin nuvi 260W GPS Receiver
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
Shower leaking
Tried new washers with no joy. Replaced hose.
Nov 16, 2008 | Home
Garden Logo
320 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
