Question about LG Tromm Electric Dryer
How to team change in the rear wheels to drum
Making lots of noise
  • tom cassidy
    tom cassidy May 01, 2015
    Hi Barry Blackburn, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • LG Master
  • 3,368 Answers
Check your spelling and add model number to your post.
Posted on May 01, 2015
2003 yamaha v star 650 classic rear brake noise.
check the wheel bearings
it indicates that the hub is moving sideways on the axle allowing the side of the shoe to contact the inside side of the drum thereby making the noise
Apr 20, 2017 | Yamaha Cars & Trucks
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
I have a Maytag front load Mod. # MFW9600SQ1 and It is making a grinding sound when the drum is rotating. I took off the back and belt to see if it was the motor but it is still making the sound. Is...
Is it making the noise with the belt removed ?? If so it is the pump has an obstruction in it most likely. As for the bearing it is not an easy job . The whole drum assembly must be removed from the case and separated.
Dec 07, 2010 | Maytag EPIC MFW9600S
Drum is making a knocking noise
it could be the rear drum bearing going out or the rear drum rollers going bad or the roller wheels beginning to flatspot or the front rollers in the same shape,you would need to remove the front cover on the unit by removing the lower kick panel screws,then remove the top cover and removing the drum belt,then remove the drum from the machine to examine all the above issues noted
Apr 27, 2010 | Kenmore 63942 Dryer
Why is my dryer is making a lot of noise during drying process?
check to see if it is a belt pulley system if it is its probably those items.
Apr 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
2001 Hyundai Accent new rear brake noise
jack up the rear wheel and spin it, do this with the other wheels chocked for safety, and listen for any rubbing sound, do this with both rear wheels and if one is bad then remove the drum again to check if the retainer has come off of the brake lining, hope this helps you.
Jan 07, 2009 | 2001 Hyundai Accent
Rear wheel
does the van shake or vibrate? does the van have tires on it ?start by switching the left rear with the right rear test drive and listen for soun if no sound then the tire has a bad steel belt replace tire if the sound is still present. jack up van and spin tire if no sound is heard replace wheel bearing and if there is still a sound look into brake drum for possible springs or clips that may have fallen into drum causing noise but i would say its more than likely the rear wheel bearing to change that u must buy a new bearing and follow instructions on replacing good
Jun 30, 2008 | 2000 Dodge Caravan
LG Tromm Electric Dryer Logo
27 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
