Question about LG Refrigerators
LG GR-P197WVS. How do I keep the refrigerator side from freezing?
  • LG Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
God is so good: so this is why I give free advice so please thank him not me.
LG GR-P197WVS. How do I keep the refrigerator side - lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-0.jpg
lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3LG GR-P197WVS. How do I keep the refrigerator side - lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-9.jpg/uploads/images/lg-gr-p197wvs-prevent-refridgerator-iizpua1124tc1voeqjalmrl5-3-9.jpg
Posted on May 07, 2015
SOURCE: LG Refridgerator GR-131R. Out of the
Good day.
Seems like your thermostat went shorted that is why you cant control the temperature anymore.
chris
Posted on Mar 11, 2008
  • 489 Answers
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Posted on Apr 29, 2008
  • 139 Answers
SOURCE: Not cooling/freezing THERMADOR SIDE BY SIDE REFRIDGERATOR BUILT IN
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
hope this helps
cheers wash doctor
Posted on Aug 25, 2008
SOURCE: My Kenmore side-by-side refridgerator is making a loud humming noise.
Sounds like your compressor is not starting due to a faulty "starter PTC" a.k.a. start relay. Or a faulty compressor. The buzzing noise you hear is the compressor trying to start. When it's windings overheat, an internal cut-off switch "clicks" off until it cool down.
Then the cycle repeats.
Posted on Feb 27, 2010
SOURCE: Water leaking and freezing at bottom of freezer in
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
LG Larder Fridge model GR-252 SBD IS FREEZING ON INSIDE BACK PANEL A LUMP OF ICE FORMS. How can I stop it?
this is a defrost problem . either the A D C a pc board on the back side of the frig . this main board controls the temp[t and the defrost . and has failed . repl it and problem is over .. mm hope this has helped .. feed back pls ..
Jul 22, 2010 | Hotpoint RLA80 Refrigerator
My LG GR 620RW fidge keeps freezing a layer of ice in the freezer. I have totally melted all the ice but I don't know why it keeps doing it again. How do I clear the hose at the back to properly drain it....
LG's design requires a drain heater element, to melt the ice that normally occurs due to the design. If this element fails, the drain clogs with ice, and so does the floor of the freezer, and then the floor in front of freezer.
Mar 18, 2010 | LG LRTBC1825T Top Freezer Refrigerator
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Freezer over freezes,whats the correct setting?
The thermostat maybe defective. It will not over freeze even at the lowest setting.
May 27, 2009 | Refrigerators
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
I have an lg model=gr-l206cvqa fridge freezer, the ice box keeps freezing solid into one big lump of ice
Ice cube tray needs to be replaced if you are referring to the ice bucket area freezing all up. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Refrigerators
MY LG SIDE BY SIDE DOESNT FREEZING
hi,
     then u got u got to change ur compressors or u gotto to refil de gas..
Sep 05, 2008 | Refrigerators
Good day.
chris
Mar 11, 2008 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
