Question about KLH Audio Players & Recorders
What goes into the low level in/out jacks and the high level in/out line clips on my KLH Ksub-10?
Any other advice on hookup would be appreciated
3 Suggested Answers
  • 547 Answers
SOURCE: i have a klh asw120 subwoofer annd a pioneer
On the subwoofer's L&R input, you'll see a tiny "mono" next to the Left input. Hook up your receiver's single sub output to this jack and you're all set.
Posted on Jun 15, 2009
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
How to install KLH asw10-20 to a 7.2 receiver
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
Jan 20, 2015 | KLH Audio Players & Recorders
Klh powered sub woofer
Low level inputs are designed to take signals directly from an amplifier's "sub out" connections. That way the KLH amplifier will use those signals to produce sound and the volume can be balanced between the main amplifier and the sub amplifier using the sub's volume controls. Depending on your amplifier and sub, that is the best way to connect them. However, be careful running the RCA cables since the low levels are more subject to interference. Keep the runs as short as possible and use high quality shielded cables for the interconnects.
Aug 26, 2014 | Audio Players & Recorders
Klh model 20 no volume
what kind of speakers do you have hooked up? make sure your cables from the speakers are good. you should have an RCA type hookup on your record player, make sure they are in there good too
Jan 07, 2013 | KLH Vintage Model 20 Turntable & Receiver
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
My KLH subwoofer (model ASW8-120B) has stopped working and emits only a low-pitched hum.. I have tried hooking it up using the ''high-level'' 2-wire inputs as well as the ''low level'' RCA plug inputs....
It's unlikely that you can find a shop to repair it for less than the replacement cost ($75ish for a comparable KLH or Sony sub)
If you're up for doing your own soldering, here's a solution for the same problem with the same amp.
If this helps, please hit the "thumbs up" for me!
Jun 26, 2010 | KLH ASW10-120 Subwoofer
What all do i need to hook up three ten speakers with a 1100 watt amp to my factory radio?
you will need to get whats called a line level converter. This device takes a channel from your factory stereo, pads the level down to a reasonable level your amp can take without causing clipping. You can then use your external amp and subwoofers. One major problem with low quality line level converters is alternator hum. Just a warning. Good luck
Mar 20, 2010 | Stingpro ST444 1850 Watts Complete...
I have a klh asw120 subwoofer annd a pioneer receiver. the hookups behind the receiver has one output and the subwfr has a l & r input. does this need a y splitter or is there a certain way to connect...
Jun 09, 2009 | KLH ASW10-120 Subwoofer
My klh subwoofer has R&L connections to speaker and R&L connections to amplifier, but my new amp has a RCA cable connection plug-in. Any way I can use the old subwoofer with the new system?
Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
Jan 01, 2009 | KLH ASW10-120 Subwoofer
KLH ASW10-120B subwoofer
I realize that this is an old problem, but folks are still finding it on searches, so here goes.
Here are the two pages of schematics from KLH. I wrote to their tech department and explicitly asked for permission to share them here.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
Jan 25, 2008 | KLH ASW10-120 Subwoofer
46 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
