Question about Refrigerators
How do I fix an ice maker that doesn't work? - Refrigerators
  • Refrigerators Master
  • 473 Answers
Depends on the actual problem. If you hear it running but not producing ice, it could be a bad inlet water valve and not actually a problem with the icemaker. If the icemaker does not run at all, it usually needs replaced. Not too much on them that is repairable to the average person.
Posted on May 01, 2015
Ice maker stopped working in a kenmore refriderator model 106 57032602
take the cap off the front of ice maher. turn the gears manualy in either direction about 1 turn put cap back. if that doesn`t work replace ice maker. MAKE SURE tube goes backon top of ice tray.
Dec 26, 2017 | Kenmore Refrigerators
Tray is full but doesn t stop making ice
The ice sensor may not be working. You can replace it if you are
comfortable working on this type of equipment. It plugs into the circuit board. The sensor can be found on the web but you can't get it from the distributor of the unit.
Feb 15, 2015 | Sunpentown SPT IM-100 Portable Ice Maker,...
Green Ice from ice maker
Make be free copper pipe corrosion.
Jan 10, 2018 | Refrigerators
Ice maker doesn't work
remove im and look into fill tube,if there is ice in fill tube,defrost with hair dryer and replace selinoid valve at bottom back side of unit.if not frozen replace im
Apr 09, 2013 | Kenmore Refrigerators
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
An apppliance company has installed three ice makers and none of the three have worked. they may drop ice once or twice in a 24 hour period. there is also frozen water in the ice bin. Can you tell me what...
you can make ice at30/31 degrees F but ice makers do not start until it is 0/4F clean all coils and if it has a condenser fan see if it works or you may be just low on freon thumbs up
Aug 12, 2009 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
