Why can't I get onto double down slots? - Office Equipment & Supplies
    Top Expert:
  • 10,875 Answers
Go to fb and complain
Posted on May 01, 2015
REMOVE CURRENT DOUBLE DOWN CASINO APPLICATION
No, this is a web based program that can be played on any system.
Jan 18, 2014 | DiLiGO Slot Machines
Print double sided
Select your printers properties
Duplex printing
You can print a document onto both side of a page. This comes in handy
when you want to bind multiple-page documents.
1 Click the Layout tab.
2 From the "Double Sides" drop-down list, select "Double-Sided".
Note
The binding orientation can be specified from the "Binding Position"
drop-down list.
Aug 22, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
Automatic Belt Tensioner pully assembly Removal / Replacement
The automatic tensioner is held on by a nut. You have to jack up the car crawl underneath and reach up between the alternator mount and the rear exhaust manifold . The access to the nut is finger tip small. You will need a 14mm 6 point socket , a short extension, a long extension, a short breaker bar,a socket wrench, and a pivot joint for the extensions. Getting the nut onto the new tensioner is the hard part. Finger tight the nut and double check that the tensioner is positioned correctly in the mounting slot. Then tighten down the nut and put the belt back on.
Jan 02, 2011 | 1997 Dodge Caravan
Dell dimension 8200 how to install ram
First of all you will need to find the specification for the right RAM type. Then just bend the two clips on the sides of the RAM slots and insert the RAM into the slots according to the uneven jacks on the slots and press it down until the clips lock onto the RAM.
Dec 14, 2010 | Computers & Internet
I recieved a ds lite with water damage and the four odd wires on my ds lite motherboard all come off does any one have a diagram of where the wires might go thanks please help
from the tom screen there should only be 2 wires 1 black and 1 white. The white wire is the mic that plugs straight onto the board, and the black wire which plugs onto the wirless insert which attaches onto the board. the other 2 wires could be loose speaker wires if there is another black and a red wire, other than that could you explain a bit further what the wires actually look like.
Jan 16, 2010 | Nintendo DS Lite Console
RESERVIOR FLOAT
The float goes into the bottom of the reservoir. If you look in, you'll see a little slot on the side down at the bottom. The float goes in so that the little tang at the bottom and pointed out.
You should have a metal clip that probably popped off. The clip clips onto the edge of the plastic in the reservoir that forms the slot for the float. The clip simply has to be pressed onto the plastic edge. The best way to do that is to get a stick and cut a notch in it. You might want to use some double stick tape so that you can put the clip onto the stick and then lower it into the reservoir and press it onto the edge of the plastic.
Oct 19, 2008 | Philips Senseo HD-7810 Coffee Maker
Zanussi washing machine.
switch off
remove plastic clamp that holds seal to cabinet and peel seal off cabinet.
the inside of the seal is held onto the tub with a circular spring. push seal down (needs a bit of force), pull outwards and seal will come away from tub.
lubricate the slot in the seal that fits onto the rim of the tub with washing up fluid.
starting at the top, push the first little bit of the slot in the seal onto the rim of the tub.#
working in both directions, push the slot onto the rim until completely on. this is a knack so be patient.
the circular spring fits into a slot on the outside of the seal. this is quite difficult to get into place and extra pair of hands will help.
fit seal onto cabinet - this is easy - and refit plastic clamp
test for leaks on wash cycle as water level is higher
Oct 08, 2008 | Zanussi Washing Machines
How to fix anew door seal on a Zanussi FL1081
turn off atmains
remove the clamp that secures seal to cabinet and peel away the seal.
the seal is held onto the tub by a large spring. at bottom, pull hard down and out and seal will come away.
on new seal, lubricate the slot that goes onto the drum rim with washing up fluid.
start the slot onto the drum rim at the top and work your way round in both directions pressing slot onto rim. this is quite hard work and you may need several attempts.
when slot is on rim all the way round, refit the spring into the outer slot of the seal. this is quite difficult and an extra pair of hands helps
refit seal onto cabinet rim - this is easy and refit outer clamp.
test on rinse cycle for leaks as the water level is higher.
water will foam till the washing up fluid is washed away
note that the seal has a specific way up indicated by an arrow
Sep 07, 2008 | Zanussi Washing Machines
27 people viewed this question
jasbo
jasbo
