Question about Sewing Machines
Needle is threaded correctly, but no thread is going into material. How do I fix this?
  • Sewing Machines Master
  • 654 Answers
1. Make sure the needle is in facing the right direction and that it is a new needle.
2. Is the thread pulled from the bobbin?
3. Check the bobbin tension and start the top tension at four. Always thread the machine with the foot in the up position. This way you can feel for snags while threading. If there are any they must be eliminated.
4. Following the instructions that I have attached and you are likely to succeed.
HOW TO SET YOUR TENSION
Real Important: The objective is to even the top and bobbin tensions equally.
1. Remove bobbin case. Put bobbin in (rotating counterclockwise).
2. Put thread under the tension plate. Let the bobbin hang from finger and bob up and down lightly.
3. Adjust tension. The bobbin should extend one inch every time it is bobbed.
4. Put one drop of oil on race the bobbin case sets on top of. Replace the bobbin case and bobbin.
5. With the pressure foot up thread the top and give little tugs as you do this. There should be no snags or resistance. Make sure the thread goes in between the tension disc.
6. Now, put pressure foot down. Give a little tug to see if there is a resistance. Set the tension to four is a good start.
7. Try a piece of rag to sew. Set the tension on top to adjust for a perfect stitch.
Posted on May 01, 2015
SOURCE: thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Posted on Oct 17, 2007
mallow1
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
  • 360 Answers
SOURCE: Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Posted on Feb 08, 2009
  • 25 Answers
SOURCE: machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
Posted on Jun 02, 2009
Australian S
  • 46 Answers
SOURCE: Replace the needle thread tension dial
If the entire assembly has fallen out you will find if you remove the top left hand cover that there is a small screw in the casting where the tension assembly goes, replace the tension body to the correct position and tighten the little screw.
Posted on Jul 02, 2009
Top thread keeps getting bound up in bobbin making a huge thread mess I can't seem to get it to stop ....done everything I know how to do but it is still happening?
Bobbin threaded correctly? Needle not bent and correct size for material? Old thread, cheap thread?
Underneath packed with lint? Needle threaded correctly. Just some things to look for :)
Aug 18, 2017 | Sewing Machines
New brother 770. Needle threaded correctly, but no thread going into material. How do I fix this?
bad timing. just as needle starts to go back up, bobbin hook must pass behind. simple one screw adjustment. look up on youtube.com. easy to do. give it a try.
May 01, 2015 | Brother Sewing Machines
The zig zag stitch is on the bottom of the fabric instead of the top how do I fix this for a Singer sewing machine model 7015
In two words, this sounds like a problem with: thread tension. Quite possibly to the point of having an entirely mis-threaded machine, whether because the thread was not routed correctly, or because parts of the thread path are missing.
(Let's review - just for a sec - the basics of how the stitch is formed. The needle, carrying the upper thread in its eye, penetrates the material. When below the material, the needle begins traveling back upward, creating a loop in the thread. (Depending upon the type of machine, either a hook or a shuttle) then pulls this loop so that the lower/ bobbin thread runs then through it. Then, as the needle retracts further upward, an arm (between the tensioning disc/spring and the needle thread path) pulls upward of the thread, tightening the stitch into place.
If, for example, there is no tension at the tensioning disc/spring, that arm will take from the thread spool instead of tightening the stitch into place.
Dec 14, 2014 | Singer Sewing Machines
What is the problem when the thread keeps bunches up on the back of material
Could be many things. Old blunt needle, wrong tension, wrong needle and thread for the material. Have you got the same thread in bobbin and needle?Also is needle and bobbin threaded correctly?
best wishes
Sep 27, 2014 | Euro-Pro 416 Mechanical Sewing Machine
How can I stop bobbin thread from jamming
This is usually caused by the needle not being threaded correctly or wrong size needle or wrong thread for the material or old thread, or incorrect tension for the material being sewn.
Jan 26, 2014 | Euro-Pro Fast and Easy 420 Mechanical...
When I embroider, the back of the material gets enormous knots in the thread. What can I do to fix it?? Thank you!!
change the needle
check to make sure the thread has not come off the thread take up lever
change the thread on top & bobbin area
clean under the needle plate & bobbin area for loose threads or lint
check to make sure the bobbin is not warped
check to make sure there are no burrs on needle plate
make sure the bobbin is wound correctly & inserted correctly
Aug 11, 2011 | Brother Sewing Machines
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Bobbin area will not work
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Jul 17, 2009 | White Sewing White 3032
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Singer Simple 3116
Your problem is a simple one.Jamming is due to thread getting trapped on the bobbin holder.All you need to do is to unscrew two screws holding the the bobbin holder clean the same and reasseble it.your problem will be solved.N.Govindarajan
Jun 09, 2008 | Singer 3116 Simple
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
