Question about Electrical Supplies
Wont start done carb overhaul has ignition spark
    Sergeant:
  • 415 Answers
Try using starting fluid. If that starts it, then you know it is a fuel problem. May need to check the carb again.
Posted on May 04, 2015
    Top Expert:
  • 10,875 Answers
Check low oil switch and filters
Posted on May 01, 2015
2002 seat leon, engine died while driving ? :o(
Do a compression test. Your engine may need an overhaul.
Jul 20, 2014 | 2000 Seat Leon
Scooter wont start
Sounds dlumb, but first check and see that the fuel is flowing into the carb. You should make sure the ignition is working properly and firing, do this by pulling the plug wire from spark plug and hold it about a quarter inch from metal while turning the engine as if starting. A strong spark should jump the gap without a problem. If the spark is nice and blue, pull the spark plug and check to see if it got flooded out and is wet. If so, dry it out, clean it, regap it it, or install a new one. Then try starting it again after adjusting the new carb by turning the idle screw all the way in, then back it out one and a half turns for initial setting. If it still has problems spray starting fluid into the carb while turning it over. You should also check the new carb float level since not all new things work as they should.
May 25, 2014 | Health & Beauty
It will turn over but wont crank
Not starting issues are usually spark or fuel problems. If you have gas getting to the carb then check your spark. First check all the wire connectors and plug wire to make sure everything is connected. If you find a loose connection fix it then try it. If not, then remove the spark plug but leave it attached to the plug wire set it on the cylinder head and turn the engine over. You should see a bright spark. If you have a really weak spark or none at all, then it may be your ignition coil or a related ignition part.
Jan 28, 2014 | kawasaki 2006 Bayou 250
23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Apr 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
After 8 years in storage my 1982 Craftsman LTV 11 tractor will not start. (B&S vert shaft eng.) It would crank when jumping the solenoid, but not start even with switch in run position. I installed...
Not sure what all you have done. Most problems are in the carb. Did you replace with fresh gas? clean the carb. check for spark and compression. use ether or starting fluid into the carb air intake.
Jul 24, 2017 | Garden
The timing on my 3hp briggs and stratton mower is so bad it wont start it is a pull start mower
Timing is fixed - or at least it's supposed to be! There is a possibility that the flywheel key has sheared, allowing the timing to drift, but not likely.
No-start on Briggs engines are usually carb related. Test for spark, and if good, overhaul the carburettor.
Mar 11, 2010 | Garden
Car wont start. Replaced ignition coil, igntion
timming belt may have jumped timming
Feb 25, 2010 | 1986 Honda Civic
I have a 1974 dt 250 same as an dt 360 the bike has sat in a barn about 4 yrs it will not start removed and cleaned the gas tank went thur the carb new plug used ignition coil compression about 50 to 75...
Compression is too low!
Replace the piston rings.
Also check continuity from engine to frame till high-tension coil...
Check if breaker points aren't dirty ( clean out with fine sandpaper )
Check breakerpoint settings
Oct 31, 2009 | 1974 Yamaha DT 360
Bike wont start. It has spark and the carb is newly overhauled. What can it be?
lack of fuel try squirting a little drop of fuel in air filter and see if it starts for a second
Oct 02, 2009 | Yamaha DT 360 Motorcycles
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
