Question about BOYO VTM4000 4-Inch Rear View Monitor
Unit ceased to function. Prior to this the unit was flickering and functioning intermittently. Any common causes of this?
    Top Expert:
  • BOYO Master
  • 45,422 Answers
Loose power wire perhaps
Posted on May 01, 2015
Temperature light red, coolant full?
Yes, but does the fan cut in? maybe the temperatur sender unit is faulty. Maybe the thermostat has ceased to function correctly.
There are a few things to check.
Neglecting to do so can cause a head/head gasket failure, probably best to see to it as soon as possible
Jun 19, 2015 | Cars & Trucks
Hd72 had colorwheel replaced turned on and worked for about 20 minutes made a sizzling elecrical noise and went blank. Turned off disconnected and reconnected power and turned back on and no picture. ...
The power to the circuit board is passing through components that are breaking down. Eventually all function will cease and the unit will not respond at all. A power surge may have passed high voltage and current to the unit causing stress on the electronics inside. professional service can trace the circuit and find the damaged parts.
Feb 27, 2014 | Optoma HD72 Multimedia Projector
Keys not working
Well, the most common cause of a non-functioning keyboard is a driver issue. If the keyboard driver has been updated by normally a third party update application, then the most recent driver must be uninstalled by using the "rollback" feature. To check this, go to "computer management" then "device manager" then find the keyboard, then "right click" on "properties" go to "driver". Check the date which the driver was updated. If was recent, around the time the keyboard ceased to function, then click on "rollback". You may have to use an external keyboard with a USB plug to do this, as of course the laptop keyboard doesn't work.
A second option is to attach an external keyboard and initiate a "system restore". Go back to a date in which you believe was "prior" to the keyboard issue.
A third possibility is a virus. Once again, attach an external keyboard and run all anti-virus programs to include "spybot search and destroy", "Malwarebytes" and your primary anti-virus program.
There is a forth possibility. If the laptop has been opened for any maintenance, and the underside of the keyboard was exposed, any dust, and I do mean "ANY", just one speck, can cause issues. This is not likely or common.
So unless there are some key events which would cause me to go down another path, one of these solutions will work!
Aug 27, 2013 | HEWLETT-PACKARD ProBook 4520s
Center channel stopped working during football game. I plan to check the center speaker with another source and then send it to the shop assuming the speaker is OK. Is this a common problem?
For that particular unit, it does not seem to be a recurring problem-- though a certain channel (or input) ceasing to function on a receiver does happen from time to time. If you find out that the speaker is okay, you can look into getting the receiver repaired.
Mar 07, 2011 | Sony STR-DG820 Receiver
How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Aug 10, 2010 | Heating & Cooling
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Mute function on the amp
A couple of questions to try and narrow this down:
1) What is the impedence rating for the speakers?
2) When the unit shuts down, will it recover on its own after a little while or do you need to power cycle it to get it to work again?
3) When the unit shuts down, is it hot?
Possible causes of this behavior:
1) Impedence rating too low causing the amp to work too hard and shutdown.
2) Excessive heat (caused by #1?) will shutdown the unit to prevent damage.
3) Possible intermittant short in the speaker wires somewhere? Loose connection?
A little more investigation will be required to find this. A repair shop would run this unit under load and monitor the outputs for heat and any spikes in the signal that could kick in the protection circuits.
Keep us posted on what you find.
Dan
Jun 07, 2010 | Marantz Audio Players & Recorders
Turntable turns intermittently so unit will not operate
The turntable fan and light all share the same feed, first check wiring for loose connections the problem though is most likely with the controller
Dec 28, 2009 | Viking DMOC205SS Microwave Oven
Unit is behaving oddly
there is probly a short in the wiring some were
Jun 12, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
BOYO VTM4000 4-Inch Rear View Monitor Logo
49 people viewed this question
Top BOYO Computers & Internet Experts
David Payne
David Payne
Are you a BOYO Computer and Internet Expert? Answer questions, earn points and help others
