Question about Garmin Forerunner 110 GPS Heart Rate Monitor Watch
IS THERE A WAY TO FIX THE 'START/STOP' BUTTON. IT WILL NOT TURN ON. IT STARTED LESS AND LESS RELIABLE AND NOW WON'T WORK AT ALL.
SOMETIMES IF I DID GET IT STARTED I HAD TROUBLE TURNING IT OFF. NOW IT WILL NOT START AT ALL
    Scholar:
  • 180 Answers
You will need to either need to repair or replace the button inside on the circuit board. If you can do it you should take it to an electronics repair shop to have it repaired. I do these kind of repairs but unless you are in the Portland Oregon area that probably won't do you any good.
Posted on May 01, 2015
The hour hand on my tag chronograph does not stop at 12 when you reset the chronograph
Try pulling out the crown to the first position. Then push upper and lower button simultaneously. The red stick will start moving 1 second per push. Repeat procedure until it reaches zero position, then push back the crown to the normal position.
Sep 25, 2011 | Tag Heuer Kirium Quartz WL111E.FT6000...
Aspen watch
this should work with your aspen watch let me know if it doesn't
http://dive.scubadiving.com/members/gearreviews.php?s=593
Quote
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
Aug 08, 2008 | JCPenney Armitron Sport Link Bracelet...
I have a watch which I use sparingly for less than two years. The watch stopped working even with a new battery.
mcdevito75 here, Sometimes not useing a watch is just as bad as over use. Try to set the time and move the hands around a bit, the mechanism is most likely a little stiff, you can also try to tap the watch with something that won"t hurt the finish, (Handle of a Steak knife) at the 2--and 4 O"clock position on the watch and at the 9 O"clock position on the watch caseing not the crystal (glass)
Jul 03, 2010 | Watches
Lost directions for ProSpirit Fast Wrap
press the mode button untill you get to the setting where the seconds are flashing.hit the reset button to menuver through the hours, minutes, days, and months.
Jun 16, 2009 | Watches
Turn off beeps
Press the MODE button until you get to the AL (ALARM) screen. Press Start/Split (Stop/Reset) (upper right button) repeatedly to turn the alarm and chime are off. If that did not help the manual can be found at www.timex.com at the bottom of the page click on manuals/downloads, click on manual downloads go to Digital Chrono/Alarms/Timers and click on the manual. Hope this helps.
Feb 05, 2009 | Timex 1440 Nylon watch
I have an Athletic Works watch and can not turn off the alarm.
the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
 A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
Jan 24, 2009 | Casio Sea-Pathfinder SPF40-T Wrist Watch
How the alarm works
i controlled the alarm by keeping the start/stop (upper right) button depressed while repeadedly pressing on the reset (lower right) button.
Nov 12, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
Setting watch
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
Mar 25, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Garmin Forerunner 110 GPS Heart Rate Monitor Watch Logo
88 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
