Question about Garden
What could cause a grinding noise when I engage the blades?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Something stuck under the deck, damaged blade, faulty or damaged blade spindle bearing.
Posted on May 04, 2015
Ceiling fan makes noise, rubbing noise?
Ceiling Fans making a Grinding Sound. If it's a grinding your hearing, most likely the ball bearings in the motor are bad. Some ceiling fans have flywheels that attach the blades to the motor. If the flywheel is sagging or has broken, the blade irons might be scraping on the top of the switch cup housing.
Feb 09, 2018 | Dryers
Ceiling fan making grinding noise
bearings are dry and noise is metal on metal you can try to oil/lube the bearings --and or a blade is rubbing on case either loose blade or bearings worn causing offset wobble
Jul 13, 2016 | Dryers
What could cause a grinding noise when the blades are engaged
blades too long or something bent on deck .perhaps a guard got stepped on too hard
May 01, 2015 | Garden
I have a toro z master 42" cut 17 HP Kawasaki zero
Could be a bad bearing or could be something rubbing against something. Are the blades sprung so they are touching part of the body or something they shouldn't Just ideas to check out.
Sep 19, 2014 | Garden
2008 Silverado Z71 grinding noise in 4 wheel high - what is the cause
Could be the axle trying to engage or it could be in the transfer case. Suggest you put it on stands all around and have some one listen underneath for exact location while engaging it.
Sep 12, 2014 | Cars & Trucks
Noise comeing from the dashboard
I am guessing you have a mechanical tacho, these have a flex drive comes off the cam or crankshaft, when these are not engaged in the drive correctly, it flicks off center causing a click or grinding noise from the tacho housing. to cure just undo tacho cable engage center cable reconnect outer cable, problem should be cured, if not send me a message with more information
Dec 02, 2013 | Cars & Trucks
Poulan riding mower grinding noise
Sounds like bad gears in transmission.
Sep 07, 2017 | Garden
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
