Question about Toys
GROVEPARK 4 LEG METAL SWING SET - MODEL#MSC-3886
GROVEPARK 4 LEG METAL SWING SET MODEL #MSC - 3886
  • 1,631 Answers
Yea, what is your question?
Posted on May 01, 2015
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
I am too short for my 125 r honda how do i adjust or can it be done.. Help???
my mrs is just the same, measure the bike whilst you are sat on it. from the number plate to the floor and also a similar fixed point on the front to the floor (the most forward fairing bolt maybe) jack up bike rear end take a look at the shock mount on swing arm. un do bolt. move shocks position in swing arm bracket until you realise where if the holes where drilled it would secure and the rear wheel would be closer to the seat effectively lowering the rear. drill new holes. start with a small 3mm pilot and move up to i think 10mm was the size. make sure that you don't make these holes to close to the edge of the metal. drill speed real slow and lots of pressure. you are drilling metal and so you need less speed and more push like you are cutting not drilling. once complete refit rear shock bolt in new hole.sit on and take a new measurement of rear number plate to floor. write down the difference between old hight and new height. undo fork leg securing bolts. 10mm socket i think. slide leg up to match the difference on the back. retighten, do the other leg. make sure both legs measure the same!!! measure the front and rear. the rear may change slightly due to angles. readjust until correct. get a small amount cut from the middle of the side stand and have it welded together. ensuring the bike stands right. done, one happy shorty. enjoy.
Apr 25, 2012 | 2006 Honda CBR 125 R
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
I have just purchaced a graco bounce n swing. ive inserted leg tube into wrong side n cant get it out. what should i do?
There is a plastic casing around where the leg snaps in. Lift this section with a screwdriver being careful not to break it. With it lifted, push down on the end of the leg that is incorrectly inserted and push down. I had the sane exact issue and this is how I figured it out. Good luck!
Mar 29, 2011 | Graco Swing N Bounce, Inman Park
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Trying to replace the motor on my maytag toploader washing machin
Hi There,
On the bottom of the front panel there should a philip head screw right above each fron adjusting leg.
Remove these 2 screws. Open the cover and lift up on the front between the drum & cover there are 2 metal clips holding the top down. Swing the top up and remove the front panel. The motor is right in front on the lower left. Let me know if this helps and thank you for using FixYa!
Jan 22, 2009 | Maytag HAV3460AWW Top Load Washer
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Toys Logo
225 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
