Question about Cub Cadet Tank Riding Mower M60-KW-LC
I have a large oil leak coming from behind the oil filter after an oil change.
It is not coming from oil filter or filter gasket
    Top Expert:
  • Cub Cadet Master
  • 51,187 Answers
Better look for a cracked block then .
Posted on May 01, 2015
Where is oil cooler on 2008 altima and how to relace gasket it is leaking
Look for the oil filter. The cooler is right behind it. Remove the l filter. Use a large socket to remove the center stud that the filter screws onto. Pull the cooler back far enough to remove the old gasket (you do not need to pull off the coolant hoses to do this). Clean up the area, install new gasket, install center bolt, install filter, start the engine, and check for leaks.
Sep 26, 2014 | 2008 Nissan Altima
Engine diagram
That is the oil cooler. Remove the oil filter. That exposes a large 'nut'. Remove the nut (and the 2 lines going in/out) and replace the oil gasket/O ring. If original oil cooler is dent or damaged, replace cooler as well. Could also just come from the lines going in and out of the cooler (put new hose clamps on).
Jan 05, 2014 | 1997 Audi A4
Bad oil leak in 2001 ot cruiser
A couple of leaks can be fairly large. An Oil Pan leak where you will see oil seeping down the sides of the pan and dripping directly below. The other is a Rear Main Bearing Seal leak and the oil will be coming from where the engine meets the transmission.
Aug 12, 2017 | 2001 Chrysler PT Cruiser
OIL LEAK COMING CLOSE TO THE OIL FILTER
if you had recently done or had an oil change done sometimes the gasket from the old oil filter sticks to the block. when you install the new oil filter it ends up with 2 gaskets and leaks around the base where filter meets oil cooler. another posability is the oil pressure sending unit is mounted just above the filter.
Mar 23, 2009 | 2000 Volkswagen Beetle
Oil leak from oil filter
There is an "O" ring between the Oil filter housing and the adapter that will leak as well. Remove the oil filter and check inside of the housing for a large nut. Remove the nut and separate the adapter from the housing. Check the "o" ring between them and replace with new "o" ring. That's where mine is leaking and I've read a couple of others that had the same problem. The old ring started out "round" and has, over time, become flat. The new ring should start out with a flatter cross section that will seal better. Good luck! (Easy Fix, but finding the "o" ring may be a challenge. Check for the ring at the Honda Dealer as the Passport is the same basic vehicle.) Do it during the next oil change........
Feb 10, 2009 | 1997 Isuzu Rodeo
Oil leak
If it's leaking from the oil filter spacer.( the 2 inch metal ring that attaches to your block, and has two rubber hoses coming out of it, and your oil filter attaches to) There is an o-ring between the spacer and the block. Take off your oil filter, remove the oil filter stud with 1 3/16" socket( or metric equivalent) and the spacer will come off. I found all the auto parts stores around me said that the o-ring was a dealer item. I bought a FRAM PH3387A oil filter and removed the o-ring on that. It fit perfectly, snug down your oil filter stud to specs, then install your oil filter. Double check that the oil filter is not double gasketed, and your are fixed!
Jan 31, 2009 | 1995 Honda Odyssey
Oil leak behind oil filter
you probably have the old gaskket still on the filter or the filter receptacle. Remove the filter and check to see if the gasket is on the filter. Then check where you screw it on there may be the other gasket stuck to that.
Dec 26, 2008 | 2004 Hyundai Elantra
2001triton v10 oil leak
i believe you are looking at the oil cooler, replacing the gasket is not that difficult, drain the radiator, remove the oil filter and it should be 4 bolts and the whole assembly comes off, keep in mind though its more common for the oil filter itself to be leaking rather than the oil cooler gasket.
Nov 27, 2008 | 1984 Ford F 250
Eng oil leak/3.8 Ltr. eng.
ok who ever installed the oil filter didnt put oil on the seal and tighted oil filter down properly this lead to seal on oil filter burning up and cracking replace oil filter and put oil on the seal all the way around
May 17, 2008 | 1996 Ford Windstar
Cub Cadet Tank Riding Mower M60-KW-LC Logo
95 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
