Question about Garden
Is there a safety switch feature on my chainsaw? It just stopped working all of sudden. It wasn't binding or struggling or anything. So I'm not sure why.
  • Kenny Durden
    Kenny Durden May 01, 2015
    Just to be thorough about this, it's not that the chain isn't moving, it won't make a sound at all.
    Top Expert:
  • Garden Master
  • 42,984 Answers
Yes that front bar is the safety (looks like second handle ) it needs pull toward you to let chain run
Posted on May 01, 2015
2 Suggested Answers
  • 2239 Answers
SOURCE: Chainsaw is new but chain
All machines today will have a chainbrake, this is normally a band that comes around the clutch drum to stop the chain in the event of a kick back, to unlock the brake, pull the hand guard fully back to the top handle until you hear the click of the brake loading, there will be an amount of force required to pull the guard back.
Posted on Feb 27, 2011
When engine is running the clutch will not turn. What could the problem be?
Sounds silly but have to activated the chainbrake by accident.? The black handguard by the top handle is the chainbrake.! Pull it back to de-activate the safety chain brake. It works by activating a brake band around the clutch drum, stopping the drive but the engine still runs, however if you try and rev it the engine will struggle under load because the clutch is trying to drive a drum which is being held by the brake.
Jan 07, 2016 | Poulan 14 Woodshark Chainsaw
Netural safety switch
Daewoo cars have track record for dependability in addition to solid construction. The most important part of a car's design is the safety features. Circumvent excessive risk while motoring by insuring that your car has the safety gear that you want. A vehicle's Neutral Safety Switch is located on your clutch in the case that it's a manual transmission, and on the shifter in an automatic. A broken Neutral Safety Switch can cause your vehicle to suddenly start in gear, causing vehicle damage or personal injury.
If you don't have the Neutral Safety Switch, your vehicle will fail to work. The Neutral Safety Switch is typically situated below the clutch of trucks which have a stick-shift transmission. The primary function of a Neutral Safety Switch is to stop your truck from starting when in gear. The car's Neutral Safety Switch acts as a safety feature, keeping you from starting the engine if the car is in gear. The Neutral Safety Switch is an electronic part which is essential while starting your car.Here's a link to what it look's like.
Mar 22, 2013 | 2000 Daewoo Lanos
I have a 90 montero and the brake lights and turn signals stopped working and I have replaced the fuses and can't figure it out.
my 91 Montero did the same thing, I finally traced it to a bad rocker switch for hazard lights. The switch was broken and it messed up brakes and turn signals. Check your switches that they work and rock properly. My hazard switch was binding turning on and off causing a short. Got a new hazard switch that worked freely and suddenly everything worked right. The problem drove me crazy, and I did replace the turn signal lever assembly first, brake switch, turn signal relay. I found dash switches on eBay.
May 22, 2012 | 1990 Mitsubishi Montero
Is the band brake nessesary or can i take it off and use the chainsaw
It's totally necessary, stop asking if you can remove it. If you think you can make a better chainsaw than STIHL, then I think you should try, otherwise, don't change anything, you're not an engineer and if you're thinking about removing the most important safety feature of any saw in existence, then maybe you shouldn't be allowed to play with one at all.
Dec 11, 2011 | Stihl Garden
1997 Lincoln Continental: Right Rear Passenger Side Power Window does not go up or down (currently up). When I activate switch on driver's door panel, dash light will dim very slightly (indicating...
The drivers door ,of course, gets worked the most. the binding is from the window regulator wearing out. they can't be fixed, only replaced. the other doors are usually the motors, from non use. As you indicated the light dims, so you are getting power to the motor, but it is locked and possibly the regulator is locked up. When the motors drags or lock, you can sometimes smack the door and get them to work again as your try to roll them up or down. also try to assist the window down as you activate it. There is only one circuit breaker for the windows.
Randy
Jun 05, 2011 | 1997 Lincoln Continental
IT WAS SUDDENLY STOPPED
you have to check and make sure the position washing machine is balance. Usually when it run and it will stop when the safety pin touch to the unbalance switch = safety switch.
Nov 10, 2010 | Whirlpool Washing Machines
Wheel is stiff. Safety feature keeps stopping
Sounds like their is a bind, you will have to have your local dealer inspect it. Either the machine needs a full oiling or thread has wrapped around something inside.
hope that helps,
chris
Jun 06, 2010 | Singer CE-100 Futura Computerized Sewing...
Bosch Chain Saw D 70745 - fuses checked but will
The lever could be in a safety position. Unlock the safety lever to get it in contact with the switch., and squeeze to run.
Oct 22, 2009 | Bosch Garden
My Craftsman 12 in compound mitre saw, model # 315 212050 just stopped turning on...feels like its not getting power. Is there a kill switch safety feature on it that IM missing? Any help is appreciated
i would think that there is an overload switch on the motor somewhere have a good look around the motor and switch gear ,it will just be a little pushin button
Sep 05, 2009 | Garden
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
