Question about Maytag Dryers
Where can I buy belt for de308 Maytag dryer? - Maytag Dryers
  • Maytag Master
  • 473 Answers
Part number should be Y312959 listed as made by Whirlpool. About $25 retail.
Try one of these sites on Google.
V&V Appliance parts
Repairclinic
Parts direct
Posted on May 01, 2015
  • 1,631 Answers
You can try to google it, or
check here...
DE308 Search Results PartSelect
Posted on Apr 30, 2015
AlmostBob
  • 550 Answers
SOURCE: My Maytag dryer Model DE308
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both types
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one,
if the dryer is the open drum type,
Posted on Oct 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Posted on Mar 27, 2009
57 varieties
  • 1653 Answers
SOURCE: how do I get to the belt on a maytag model de308
Take off the rear panel.
Posted on Nov 10, 2009
TheMobilian
  • 8220 Answers
SOURCE: Need to locate the heater for the Maytag Dryer
unplug the dryer, remove these screws. Get the front off. The heater will be in a mailbox. Note: The element cost around 10 bucks you do not need to buy the whole mailbox which could be way expensive.f9f5c6b.jpg
Posted on May 04, 2010
Daniel S
  • 4323 Answers
SOURCE: How do i change the
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Posted on Sep 20, 2010
Where do I buy belt for Maytag de308 dryer?
There are various different appliance parts suppliers that you can find online to purchase a belt for your dryer. A couple of them are Sears parts direct, repairclinic.com. You could also check locally to see if you have a repair parts place in your town.
Apr 30, 2015 | Maytag Dryers
I cannot figure out how to get my Maytag DE308 apart to replace my dryer belt.
Two screws at the base are removed first (after yall unplug the dryer)
Your belt is a 312959
It goes back on like this:
Notice the slick side of the belt goes to the drum.
Get the belt down in the groove on the tub and you will have trouble.
Use zoomspout oil to lube the rollers and idler. It is safe for dryers and can be purchased at Ace hardware stores. Clean her up and party on!
Aug 07, 2011 | Dryers
So we have a Maytag DE308 and for some reason whenever we try to push the dial in to turn it on, it buzzes but will not start. Any ideas as to what this could be?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 28, 2010 | Dryers
Where can I buy a replacement belt for my Maytag Neptune MDG5500AWW dryer?
Nearly every appliance store and appliance repair shop sells replacement belts. Your area Sears / kMart retail store will have them, too. Many hardware stores sell them as well.
if you don't mind waiting, you can find them online, too. Here's a list of places that Google found for Maytag Belts. You should use a combination of Maytag dryer model number and the number that appears on the belt to obtain a replacement.
Oct 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do i change the belt on a model No. DE308 maytag dryer
Hi
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
Need to locate the heater for the Maytag Dryer M#DE308
May 01, 2010 | Dryers
My Maytag Dryer model DE308 takes 2 hours to dry a load of clothes. I have air flow, but after an hour, the clothes are still damp. THe dryer does not have the heat that it used to. I know that with the...
Good day,
Your right on the heating element.
If your positive the vent system to the outside is clean, then
Remove the front panel of the dryer, and inspect the blower wheel. If worn on the shaft(slipping), it needs replaced.
2. Remove the whole front panel to access the blower housing and the chute going to the lint filter. Clean as needed. (common problem).
3. If everything checks clean, then the thermostat that is mounted on top of the heating element canister is the most common problem but is only one of the thermostats.
Maytag uses a lot of air versus heat for drying. That is why it is important that part of the system is correct.
Mar 14, 2010 | Maytag Dryers
My Maytag dryer Model DE308 is very noisy. sounds like something is catching or grinding. can I fix this?
good roller
worn roller
  • remove screws
  • unhook top clips
  • tilt top up
Oct 17, 2008 | Dryers
Dryers Logo
67 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
