Question about Electrical Supplies
Generator starts just fine, but when you put any load on it, it trips the overload switch. even a 110 light blub.
    Top Expert:
  • Electrical S... Master
  • 51,191 Answers
I would contact the manufacturer and see what they tell you
Posted on May 01, 2015
Not putting out any power to plugs
Have you used it before? If so have you checked to see if the overload switches are tripped?
Aug 26, 2017 | Electrical Supplies
Eu6500is generator trips to red unload when ac is on
Air conditioner compressors require a greater amount of electricity (measured in both volts and amps, but the amps are what is causing the overload). You will need a larger generator to run your AC. You might be able to run a smaller AC unit, but always check the Amps required and compare that to the Amps the circuit breaker on the generator is rated for.
May 30, 2016 | Honda EU6500iS Inverter Generator
I have a Honda eu2000i generator to run a Husky TAW-1524p air compressor. Initial start/run is fine but subsequent compressor restarts as demand for air is required, put the generator into overload....
If your mechanical enough to figure out how to lower the air pressure switch on the compressor it would help with start up loads. For instances if your pressure switch is set for 75 psi. Lower this to 60 psi. or as low as you can and still operate equipment. Otherwise depending what horsepower and voltage {guessing 110 vac) the motor is, I would try an Hard start capacitor for refrigerators or air conditioners. They are rated by horsepower and have a built in relay that kicks it off automatically after starting . You can find these at any appliance or a/c & heating supply house.
May 11, 2014 | Heating & Cooling
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
Oct 05, 2017 | Wolf Manufacturing Electrical Supplies
Generator was running just fine. it's a bsv5500-w overloaded the unit by mistake. tested with meter and found 86 volts. shut unit down and now only puts out 5 volts on each leg
are you sure the breaker didnt trip when overloaded,as this is what the breaker is for and would explain the ghost voltage of only 5 volts at the outlet
May 30, 2011 | Porter Cable 5,500 Watt Portable Generator...
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
No 240V
check for a circuit breaker that is tripped, as well as a switch that enables 240volt (at the cost of 120 volt current being cut in half.). The switch puts the alternator windings in parallel (120volt full power) or series (240 volt @ half 120volt current).
May 02, 2010 | Northstar Generator 18 Hp, 10,000 Watt,...
Generator won't start
Some of the generator has a control or tripping device like over speed, over voltage, overload or overcurrent or other trip device, try to find & reset it.
Mar 09, 2009 | Electrical Supplies
Electrical Supplies Logo
42 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
