Question about Samsung Refrigerators
Freezer side wont freeze
Light is flashing on the frer side of a rs2533sw side by side refrigerator
    President:
  • 1,653 Answers
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting from the condenser has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Posted on Nov 06, 2009
Evaporator in freezing over then causing water leak
Just saw your post, If you still want help let me know. I have the service manual. Thanks, Sea Breeze
Jun 13, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Ice turning into a solid block in freezer. Samsung Refigerator
Hey, Your defrost thermostat or defrost heater may need to be replaced. The frost should be removed every 8 hours automatically. The ice is not freezing all the way into cubes because the temp. is too warm in the freezer to make ice.
The wire may just be a ground wire BUT it may have electrical current going in it.
This is dangerous and need to be repaired. Hope this helps.
May 06, 2009 | Samsung RS2578BB Side by Side Refrigerator
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Refrigerators Logo
497 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
