Question about Irons
I need and on /off switch for my Eurosteam cermanic iron
    Top Expert:
  • Irons Master
  • 45,382 Answers
Google it
Posted on May 01, 2015
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
Need help with Kenneth Bernard Hair FLAT IRON, not a clothes iron!! Model # is KB2010.
The Kenneth Bernard Vibe Flat Iron - YouTube
? 2:15
www.youtube.com/watch?v=lQklW8kNO90
Apr 7, 2015 - Uploaded by Chatters Salon
The Kenneth Bernard Vibe Flat Iron ... How I curl my hair using aflat iron, extensions and bump its ...
Sep 15, 2015 | Irons
How can I repair a constant steam on a EuroSteam Evolution Steam Iron
what is wrong with it? does it not come out?
Jan 28, 2015 | Irons
Philips iron keeps turnning off
We have the same problem here. The station only switches off after some time, but the iron itself keeps being switched on. So you manually have to switch on the station many times during ironing which is very annoying (for my wife). This was working before and we have tested here on different circuits already.
Sep 01, 2014 | Philips Gc8340/02 5 Bar Steam Generator,...
The iron of my steam generator does not heat up
I had the same problem. You need to disassemble the iron itself. From memory there are two torx screws near the cable entry and there is also one under the coloured part on the handle at the switch. Yo need to take off the cover to get to it. Once you get the iron apart you need to get to the base element. On the top of it is a bimetallic switch element. I discovered that I had some carbon build up between the contact points of the switch. I cleaned these (no need to remove) with some contact cleaner and rubbed lightly with fine grade sandpaper. Reassembled and has been working fine since
Jul 08, 2014 | Tefal Pro Express GV 8120 Iron
I just purchased a Eurosteam Iron & was given instructions to view a video on the web at www.backplusonline.com/eurosteam_help/ but it does not come up. I just want to go over it to be sure I do it...
make sure your adobe flash player is updated,, when I went to the site you listed,, I clicked on the 3rd option for that link and it opened right up,, if not try this one, thats where it took me when I opened it,,
http://www.backplusonline.com/eurosteam_help/home.htm
May 04, 2011 | Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
Irons Logo
298 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
