Question about Garden
Chain saw motor is smoking - Garden
  • 1,631 Answers
Specific question was probably intended to ask...
Why is my chain saw smoking?
Chain Saws have to have oil mixed in with the fuel.
Use a good high octane fuel and the mix ratio is usually 32:1 - 50:1
It is very possible that there was too much oil mixed in with the fuel. Or... Wrong oil mixed with fuel. I have even had this experience within my family, my son had a can of mixed fuel already in a can that was not "Marked". Our garden tool gas cans have specific markings on them "Mixed Fuel" or "Garden Tools Only" or "50;1" written on them with a Black Marker. Well this fuel was not marked and I mixed it once more, with more 2-Cycle Oil. Well, needless to say, we had a String trimmer that smoked to all heaven. Fouled plug came quickly.
Good Luck.
Posted on Apr 30, 2015
  • 3,519 Answers
Hi Mark:
I'll go over the basics so please ignore what you already know.
Chain saws are 2 cycle which means the gas must have oil added. The ratio is 50:1 typically.
Chain saws are air cooled so they get HOT. They like to be kept clean, and a build up of oily sawdust is an invitation to an unwanted fire.
The chain is lubricated by a thick oil that gets put in a different tank. If you run out of chain oil, the chain will get really hot and you can actually ruin the bar by overheating it. A good rule is to always fill the chain oil tank (with chain oil) at the same time that you fill the fuel tank (with gas/oil mix)
Make sure the chain is kept SHARP. A blunt chain makes the saw work harder and causes friction which generates heat.
On a regular basis, take the bar off and clean the brake assembly and all the bits and crannies. Compressed air and solvent will make the job easy.
Chain tension should be kept snug but not too tight. I like to be able to lift the chain at the centre of the bar and have the underside just barely clear the groove in the bar.
Lots of bars have a roller at the tip and there is a fitting to inject grease. It's a good idea to use it regularly.
I think that about covers it. If you have any specific questions, send 'em on.
My Remington electric chain saw motor is smoking and quit working
The motor has burnt out. Probably trying too big a cut. Its a new motor or a new saw I'm afraid.
Feb 02, 2014 | Remington Garden
Why is my drill smoking when I cut branches?
Sounds like it is overloaded, could be if the chain is blunt. New rotor in the motor might be needed.
Jun 01, 2013 | Makita UC120DWD 12V Cordless Chain Saw Kit
I have a Ryobi electric chainsaw just used it and smoke came out of the grill Help! where the motor is.
if you spilled oil into the electric motor it will smoke you can get a spray can of electrical contact cleaner spray it into the motor and clean out the oil let it dry overnight and try it again
Sep 03, 2012 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a 435 husquvarna chain saw it is hard to start plus it idles high and it smokes and the chain keeps spinning when i let off the trigger
if it is hard to start and smokes sounds like the fuel is to old and the oil to gas mixture is wrong start off with some fresh fuel gas is only good for 30days in small engines
Aug 22, 2012 | Husqvarna 450 e-series 18" Chain Saw
CRAFTSMAN chain saw blows smoke out the exhaust. New ring ???
a chain saw has the oil mixed into the gas if it is not mixed right it will smoke that is the only source of oil to the engine mix up a new batch of fresh fuel and oil mix it will be fine
Jun 28, 2012 | Garden
Blade were a bit stiff when machine switched causeing the motor to smoke a little and stop
if your talking about an electric chain saw, you have burnt out the windings on the motor and the chain saw is now in need of a new motor. If the saw was less than $100.00 US, you will most likely not be able to get it fixed cheaply enough and might just as well buy a new one. If it is brand new and under warranty, you can most likely get a replacement for free but you will have to contact the actual manufacturer, you can also try the store/dealer where you purchased the saw
Mar 22, 2011 | Garden
Electric chain saw, motor smoked, stopped running. Worth fixing?
Till you get the motor and get the new motor insatlled you will have more into it then a new one...
heatman101
Aug 19, 2010 | Remington Electric Chain Saw
Remington Polesaw 10" motor is smoking?
Sounds like either the motor is going or that you need a new chain. Is the chain old and dull and is it difficult to cut wood? If so I would try running the saw without cutting and see if the motor smokes. If so the motor may be on it's way out. If you smell an electrical motor winding smell, it's probably time for a new chain saw. I don't know that I would get a new motor for yours as it probably at least $50 and you might want to consider going to another brand like Poulan. Hope this helps!
Mar 16, 2010 | Remington Polesaw Wizard
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
