Question about Kenmore Series 80 Creme Front Gas Dryer Door
Does this dryer require 110 or 220 amps? - Kenmore Series 80 Creme Front Gas Dryer Door
  • Kenmore Master
  • 932 Answers
A gas dryer usually only takes 110 volts not amps. All electric dryers take 220 volts.
Posted on Apr 30, 2015
I am considering buying a used unit but need to know the amps requirement
Most dryers require a 220VAC 30 AMP circuit. Some of the exotic ones use up to 50 amps but not many domestic ones.
Jun 08, 2011 | Dryers
My Bosch Axxis 5410 dryer won't start. The time lights up and the status light says drying, but the dryer doesn't start. There's a little dot on the lower right hand of the time remaining which hadn't...
This type of diagnosis will require accessing the internal components & making voltage & resistance checks with a volt/ohm meter. There are several different components that could cause this symptom & yes it is possible that the door switch is bad. This model of dryer should only be worked on by an experienced, trained technician due to all of the electronic controlled parts. richroth_121.jpg
Mar 20, 2011 | Bosch Axxis WTL 5410 Electric Dryer
What are the dryer power requirments (voltage and amps) for installation?
Most all electric dryers in the US are 240 volt 30 amp.
Gas dryers are 120v 15 amp.
heatman101
Oct 28, 2010 | Whirlpool Dryers
Dryer
Check the idle pulley & it's belt. If it's worn, replace it. If that isn't the problem, check to see if the drum is supported on wheels or rollers. Sometimes these can wear and require replacement.
Another common cause of a noisy dryer is a clogged blower wheel. Check it for lint and clean it if necessary. If it appears worn, it will require replacement.
NOTE:- Always disconnect the power before doing any type of dryer repair.
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 15, 2010 | GE DBSR453EBWW Electric Dryer
What is the amp requirements
For a dryer you need a 30 amp 2 pole breaker and 10 gauge 3 wwire with a ground...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Apr 22, 2010 | Kenmore Elite HE4 Electric Dryer
Bought a drier from the us. have problem using it
Is the house wiring capable of handling the amp load from the dryer atleast 30 amps would be required to run the dryer.
Jan 16, 2010 | Dryers
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
ELECTRICAL REQUIREMENTS
ELECTRIC Dryer
CIRCUIT - Individual 30 amp. branch circuit fused with 30
amp. time delay fuses or circuit breakers.
Use separately fused circuits for washers and dryers, and DO
NOT operate a washer and a dryer on the same circuit.
POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
Hz, Alternating Current.
POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
conductor power supply cord NEMA 10-30 type SRDT rated at
240 volt AC minimum, 30 amp., with 3 open end spade lug
connectors with upturned ends or closed loop connectors and
marked for use with clothes dryers.
WARNING – Risk of Shock. Appliance grounded to neutral
conductor through a link. Grounding through the neutral link is
prohibited for (1) New branch circuit installations (2) mobile
homes; (3) recreational vehicles; and (4) areas where local codes
do not permit grounding through the neutral, (1) disconnect the
link from the neutral, (2) use grounding terminal or lead to
ground appliance in accordance with local codes and (3) connect
neutral terminal or lead to branch circuit neutral in usual manner
(if the appliance is to be connected by means of a cord kit, use
4-conductor cord for this purpose). USE COPPER CONDUCTOR
ONLY. The dryer MUST employ a 4-conductor power supply
cord NEMA 14-30 type SRDT or ST (as required) rated at 240
volt AC minimum, 30 amp., with 4 open end spade lug
The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
Kenmore Series 80 Creme Front Gas Dryer Door Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
