Question about Garden
Trying to find ignition points - Garden
    Top Expert:
  • Garden Master
  • 46,556 Answers
Probably is electronic ignition and will not have any
comment with the problem for better answers
Posted on Apr 30, 2015
I have a 1993 ford Econovan maxi . I have ignition point . What is the gap on the ignition point . Thanks
point gap is .40 to .50 mm ( point 4 to point 5 mm) or .015 to .20"
most point distributors are at the .02 " mark but check and adjust as points to wide will misfire under load or lack power if too close
point gap variations can change ignition timing
Nov 20, 2016 | Ford Cars & Trucks
What is the ignition point gap?
In older engines with traditional points-condenser-coil ignition systems the dwell if the ignition was set by the gap between the points. The points act like a switch that opens and closes the circuit of the primary side of the ignition coil.
All later engines use electronic ignition that do not require points.
Mar 28, 2016 | Cars & Trucks
Look for a coil for 1981 suzi GS550L
You can narrow the search by looking for any twin lead 12 volt points ignition coil, as long as you dont get a cdi, or electronic ignition coil, any point coil will do the job
May 08, 2011 | 1981 Suzuki Gs 550 L
I have a 1972 Honda xl250. It sat outside for 10 years before I got it. Alls it needed was a carb and it cranked after the 4th or 5th kick. About a week later it quit running. I figured out that it was'nt...
You are probably dealing with dirty,burnt,or shorting points. Try replacing the points located at the end of the crankshaft under the cover held on by two screws. You may have to install and reinstall the points several times before you can get the new points to work. Chances are the points in the machine are almost 40 years old. Also , Honda ignition systems run off the battery. In most Honda models if you do not have a good, charged battery , you will not get spark.
Dec 18, 2010 | Honda Xr 250 Motorcycles
Trying to change the points on an old briggs and stratton 8 hp engine
Need to know what model Older engines have points "under" the flywheel. Use a wheel puller to remove after removing the nut in the center of the flywheel. Newer motors have an electronic ignition module. Follow the small wire from the magnetio. If it goes under the flywheel then you have points. If it goes to a small device on side of motor, you have electronic. You can go to http://www.briggsandstratton.com/ and look up your odel number.
Jun 23, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
How to determine if a condenser is still functional.
The ignition condenser is needed for good coil saturation and is directly related to the voltage output of the coil, the weaker the ignition condenser is, the weaker the spark will be from the coil.
The signs to look for when replacing the ignition points are burnt or pitted contact surfaces at the breakers, and for a worn down rubbing block. (where the points contact the cam lobes inside the distributor)
The only things that you can do to prolong the life of the ignition points is to make sure that the rubbing block on the ignition points and the distributor cam lobes are properly lubricated with die-electric grease, and make sure that the dwell angle is properly set. (you would need a dwell meter to set the ignition points properly)
The only reason that the engine would stall from the ignition points is because either the condenser burned out, or the rubbing block wore down and the ignition points closed up. (The ignition points should open and close to provide a primary signal to the coil, if they do close up, you can get home by using a piece of a match book cover to set the gap for the ignition points, it is approximate enough to work well enough to get you back home if stranded from closed up ignition points)
I hope that this was helpful to you in any way.
Apr 27, 2010 | Isuzu Pickup Cars & Trucks
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
