Black screen but can hear audio whats wrong. On my laptop. My 4 year old clicked somewhare on the screen. I didn't see. It was working perfectly before.
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Look at your function keys there will be one with a pic of a monitor... You have to hold the function key down while pressing the one with the monitor... Sounds like you switched it to external monitor mode by accident
Posted on May 03, 2015
    Top Expert:
  • Computers & ... Master
  • 46,272 Answers
Try F7 of F8 all makes are different as you should know and you didn't include that information .
Posted on May 01, 2015
TULOA
  • 57 Answers
SOURCE: hp laptop pavilion acts like it's booting up but screen is blank?
May I ask what model it is?
The dv9000 model if you havent been told had some that had bad motherboards and that sounds like what mine problem was.
If its a dv9000 then you may want to talk to a HP agent about that.
Posted on Dec 17, 2008
  • 77 Answers
SOURCE: black screen
There are only three issues it could be...
1. The ATI video card has become warped due to overheating which woulod need to be replaced. You can find them used on Ebay for around $65 or new for around $125.
2. The cable has become frayed that connectects the video card to the inverter board due to opening/closing the laptop. Like $7 on Ebay.
3. The ribbon cable connection to the LCD panel itself has started to come undone which is also a common problem. Around $125 on Ebay.
You can try pressing down above the F5 key to see if the screen will come back up.
-Please give me a thumbs up :)
Posted on May 08, 2009
Geekman
  • 32281 Answers
SOURCE: Laptop screen goes black, no backlite
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
  • 10 Answers
SOURCE: My Monitor is divided in 4 identical screens
most likely the resolution of your screen is too high for the LCD to handle. Go to desktop settings and go one notch lower and that should do the trick.
Posted on Sep 02, 2009
jennifer720
  • 830 Answers
SOURCE: screen won't work on HP laptop
This may be caused by the video graphics cards. If you have a warranty, check with HP and they will fix for free as they warranty all hardware for two years.
You can check to make sure it is the video graphics or the screen by running a simple test. Get a monitor and attach the laptop to the monitor. If you see a picture, then the screen (probably backlight) is out. If you do not see anything, then it is definetly your video graphics card. You can order a new screen or VGA card on eBay, which I highly recommend to save money. Get a friend or you can put it in, just make sure you put the laptop back together perfectly and protect from static electricity.
It is easier to get another replacement screen if the backlight is out because these can be hard to replace. The backlight usually cost a couple of dollars but the frustration of trying to replace is like trying to replace a lightbulb in a very tight spot. A screen will run you around 40 dollars. If it's the VGA, then you are looking at 60-90 dollars.
Posted on Sep 13, 2009
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
Laptop screen not working
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Oct 13, 2012 | Acer Aspire™ 5633WLMi PC Notebook
My hp dv2000 is almost 2 years old it had been working well but a few days ago it stopped showing the screen anymore it only shows the backlight. before that it was not loading up at all. Now i can hear...
Hello. I could be hard drive failure if you keep hearing noise. What you need to right now is to backup important data ASAP. You can backup files with your Windows built-in tool or backup hard drive without booting Windows.
Choose the one you like and get a new disk. Do fresh install or restore backup image on that drive. Best Way to Backup Hard Drive without Booting Windows
Oct 11, 2017 | HP Pavilion dv2000 Series Laptop Full...
I have an Acer aspire 5534 that is less then a year old. I noticed that the screen started to have red lines and the coloring was off today so I restarted it. It then had a white screen so I turned it off...
Hi
The problem with your PC Notebook has to do with the screen.Since you can hear the sound then your screen might be damaged maybe mistakenly.
You just have to get to the right store and replace the screen so your notebook can work perfectly.
GOODLUCK
Jun 16, 2010 | Acer Aspire 55345410 Notebook
Camera displays what it sees but records blac
Hello sir/ma'am, hope this works, try a different player for your videos.
Feb 23, 2010 | Logitech Webcam
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Audio but no picture
maam/sir maybe its flyback is deffective,,,,,,or kindly adjust the screen focus of it,,,,,thanks and hope to help you!!!
Feb 02, 2008 | ViewSonic N3250W Television
Compaq Presario R3000 backlight problem
I had the same problem and the solution was pretty funny! All it was, was the little thingie that gets pressed down as you close the lid on the laptop got wedged in the hole so it didn't pop out when I opened the lid! Solution......simply pop the thing out with a paper clip!
Jan 06, 2008 | Computers & Internet
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
