Question about Yamaha Electrical Supplies
What is the reason oil steaming in abundance ginrator yamahaef6000
    Sergeant:
  • 415 Answers
If oily smoke is coming out of the muffler, then it is an indication that the rings are bad. Make sure that the oil is at the proper level.
Posted on May 04, 2015
2000 5.3 tahoe gas in oil
Fuel injector problem , leaking fuel pressure regulator ,
Causes of gas in oil
On my 94 Chevy blazer, gas in the oil was caused by a ruptured diaphragm in the fuel pressure regulator that is attached to the fuel injector. Flooding the engine. An over abundance of gas in your cylinders will wash down your cylinder walls and accumulate in the oil pan.
Jan 21, 2017 | 2000 Chevrolet Tahoe
Name for a women meaning abundance
Caleb-Ephratah abundance bearing fruit ... Israel
Ephrath abundance bearing fruit ... Israel
Falala born in abundance ... Africa
Mirias abundance Greece
Zuna abundance Africa
Nov 13, 2016 | Computers & Internet
Intercooled 3.1 1996 horizson. replaced turbo. still getting white smoke. water is overheating with in 10mins of driving. losing half to one litre oil.
the HONDA Horizon (Isuzu wonder box)
what engine. exactly .?
3.2 L 6VD1 SOHC V6
3.2 L 6VD1 DOHC V6
3.5 L 6VE1 DOHC V6
3.0 L 4JX1 TD I4
3.1 L 4JG2 TD I4
x1 or G2?
floods, wot cranking cuts fuel and starts any flooded engine,
it's overheating that wins the First order failures rule sets.
nothing else matters. cure that first.! find cause! first.
sounds (im deaf there,lol) that smoke is out tail pipe end and dissipates fast and is not smoke but steam, , oil smoke smells like burning oil and lingers. steam smells sweet like burning Antifreeze.
AF steam is a blown head gasket or far worse.
do a compression test first to see if it's even worth fixing????
most are NOT. (unless free labor, sure)
first learn steam from smoke
serious , watch moms tea pot. see that steam goes away fast.and very uniquely , now watch burning oil.
remove dip stick, drop the drip of oil on hot exhaust manifold.
smell that, that is oil burning, and lingers.
this will last you a life time of blown engines..... just one look and bingo. (my instructor in 1965 did in front of class)
got oil in the AF/ CARBON chunks in same.
water in oil, ? pan, engine . milky oil.
rad leak down test fail? can be lots of reasons even a cracked block.or head. not just gaskets.
Mar 23, 2015 | 1996 Isuzu Trooper
Are there large oil deposits in North Dakota?
Yes. Extremely abundant deposits, the you enve can't assume.
Jul 01, 2014 | Computers & Internet
Why oil is leaking from air cleaner 1999 chevy venture?
Hi
The engine produce little oil steam when is at normal temperature, this is normal.
This steam goes to the air cleaner for recycling.
Now, the reasons to see oil dripping from the air cleaner are:
Engine oil overfilled, or engine breather valve( if fitted) faulty, or the piston rings causing the pressure to scape into the oil sump ( this means engine damage).
get a technician to chem it.
good luck.
May 04, 2014 | 1997 Subaru Legacy
Why in oil coming air cleaner intake hose? Leaves a puddle every time I stop.
Hi
good luck.
May 04, 2014 | Chevrolet Venture Cars & Trucks
After changing thermosat car is now smoking a lillte from the driver side radiator area
Smoking where.? tail pipe end.?
over heats, when, moving at 60mph
or only stopped.?
if that smoke is during a hot running motor, and is steam
the head gasket blew (or worse)
oil smoke burnt lingers a long time, steam goes away fast like tea pot.
smoke smells like burned oil, steam smells disgusting sweet due to
the coolant is 1/2 Glycol.
over heating has many reasons.
only stopped?, bad rad, bad pump, bad stat, bad fan clutch.(or elect fan)
fails to over heat moving, usually is bad fan (action)
steam at tail is coolant burning.
Mar 21, 2013 | 1992 Geo Storm
Can i use eucalyptus oil in a vicks steam humidifyer
To the best of my knowledge there is no reason you could not saftly use eucalyptus oil in your humidifier.I have never heard of this causing any damage to these humidifiers. Thank you.
Mar 10, 2011 | Heating & Cooling
The temp light on my volvo s70 keeps lighting up. the guage doesn't go any higher than midway up the guage, but the coolant reserve now has a crack and the excess coolant is steaming out of it.what can i...
the only reason coolant would be steaming in the reservoir is if it were steaming out of the radiator into the reservoir. consult local technician to see if your engine coolant temp sensor is operating properly; most likely a bad engine temp sensor.
Oct 06, 2009 | 1999 Volvo S70
Electrical Supplies Logo
41 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
