I hook speakers to output,sounds good but volume seems low even turned allway up using mikes as imput,any ideas.I'm using 8ohm load speakers on the 8ohm term. thanks
  • 2,827 Answers
Microphones have very low levels. Most times we need to use a "microphone preamp" or mixer to boost the mic levels.
Posted on Apr 30, 2015
Recommendations for replacement 6 inch speakers with the Jensen AWM 968? They are for my rv, and are the only speakers in it. Thanks in advance for any help!
In-car entertainment systems, especially the types chosen for camper vans, etc., are often capable of quite high power outputs and usually need speakers capable of being driven at those high power outputs without damage.
The trouble is, such speakers usually don't sound so good at the very low volume settings needed for evening and late night use in a campsite environment to avoid annoyance to neighbours.
It is a big problem choosing speakers that sound good at low volume and yet can withstand the higher volume needed to overcome the wind and road noise of driving. There have been many technological advances in speaker design and a hi-fi specialist will undoubtedly be able to make suitable recommendations that are resistant to damp conditions, long-lasting and with cones free enough for good reproduction at ultra low volumes but robust enough to withstand high power outputs and such drive units are likely to be fairly expensive.
For myself I would choose to use a dual speaker system with a multi-speaker system comprising several low-powered speakers strategically placed for low volume use and a fairly standard high-powered system for normal use and a selector switch.
Aug 01, 2016 | Jensen Car Audio & Video
Evrything hookup there is no sound iget a good signal in the back of the sub so whats the problem
try connecting a speaker to the sub output terminals at low volume and see if it has loaded output, if it works , your subwoofers voice coil is open/blown
Jan 29, 2014 | Behringer EUROLIVE B1500D-PRO Active 15"...
M70 speaker
8 Ohm refers to the nominal impedance of the whole speaker. How would you 'use' 4 or 6 Ohm? Any modern amp should be able to handle 8 Ohm. The M70 have relatively low sensitivity, and require more output-power for high sound-volume.
Sep 26, 2013 | Mission Audio Players & Recorders
Does using subs also help increase volume (as well as bass) - and crackles question?
There are several issues here... You can connect subs in parallel BUT they need to have a crossover built it otherwise you are sending highs and mids to the subs which won't like it. Properly set up, there should be NO crackling on either channel.
Make sure that no clipping is going on, including in the effects. A set of headphones is a GOOD idea when analyzing problems. Twelve inch speakers are pretty marginal for 300 watts... I have used 15's and 10;s on my PMP3000 and PMP5000 units with no problem at REASONABLE sound levels. With 15's we can run at 95 Db which is OSHA limits... My PMP's were beyond repair units and I have repaired them... got a good deal on them. PLEASE read my tip on here about channel A of the PMP mixers. IF you use Speakon to 1/4 inch speaker cables, THE sleeve of Channel A is the "hot", not the tip of the plug. It is easy to get this grounded and kill channel A of your amp. There is NO mention of this in the user documents and I discovered it when repairing the units. Should you get a failure that pops the fuse, DO NOT replace the fuse until the internal damage is repaired. A lot of craclking can come from blown speakers. Swap your sides and make sure the problem is not with a particular speaker. I had a Peavey that was crackling and found the noise was the logo on the grille that was rattling...
Nov 24, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I HAVE TROUBLE HEARING MY CONTACT
Hello there!
Dear Esther M Shane, if you are having problems with hearing other skype contacts, please do next :
Check your output(speaker) volume, put it on maximal,
talk with your contact, advise him/her to volume up their output, or to possibly change their quality due to equivalent of your chat.
Its not really your fault if you cant heart their output very well, those people should check for problems with their imputs, ofcourse if you done all checkings I have told at the text up there.
I wish you good luck and a lot of quality usage of skype!
Sincerely
Aleksandar Adzic
Apr 17, 2010 | Skype IM
No sound
Well first of all, is it hooked up properly?
I had a viewsonic which had both speakers and a mike. So you need to connect 3 things:
1) The vieo siganl,
2) The (usually) green ouput from your PC sound card ouput to the minitor speaker input,
3) The (usually) pink cord from the monitor's mike-out to your sound card mike input.
Then, next, there are controls on the Viewsonic, one is a mute function. Turn off the mute and crank the output level all the way up, those little speakers do not have much punch to them.
Finally, you need to go to your sound card's control panel, and turn up the volume to the speakers, and of course, turn off the mute.
Another thing you may want to do is test your sound card outputs with a real pair of speakers... (Surely someone will loan you a pair for a minute -- ordinary CD player speakers would do.)
Good Luck!
Sep 08, 2009 | ViewSonic Computers & Internet
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
May 11, 2009 | HP Compaq JBL Pro (401508-001) Computer...
ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Oct 29, 2008 | Onkyo TX-DS939 Receiver
Car Audio Cutting Out
stereo is detecting a short , or low load on speaker wire and or speakers .Go behind car stereo , disconnect all speakers and apply a known good speaker to one of four wires and see if volume works normally ..If it works use same speaker on all outputs one by one ..If all are okay then you should figure out what speaker and or wires are causing issue..Also make sure your ground is okay
Dec 01, 2007 | Pyramid 4 X 10 SPEAKERS Car Speaker
60 people viewed this question
 Grubhead
Grubhead
