Question about Sharp SC-9650 Shelf System
Cannot open cd door. screen says M ERR - Sharp SC-9650 Shelf System
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Sharp cd-ba1600 door won't open
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 07, 2008
Erorr code -Err 1 is showing on our machine. Any ideas? Thanks.
Is this a Haier Washing Machine?
'coz I found an answer on their site..
"Q. The display shows Err 1. A. The door is open or not properly locked shut. Open and close the door, or firmly push the door shut until you hear a 'click'. If the problem continues, call the customer help desk or an approved service engineer."
Src: http://www.haier-uk.co.uk/support/faq
Hope this helps.. :)
Jun 09, 2011 | Washing Machines
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
How to get service manual - Denon M10 (UDCM-M10) - CD Player
I woul try to download it from a reliable site and print or see if Denon sells it
Feb 09, 2010 | Denon D-M10 CD Shelf System
CD player saying ERR
have you tried using a cleaning disc on your cd player
Dec 16, 2009 | 2004 Chevrolet Cavalier
Cd stack in cd player,screen shows err
My CD Player did the same. It showed an "ERR" message when trying to detect the beginning of a CD. I thought that the CD was dirty and wiped it down. Then I discovered that the player would detect the CD when the car was idle, but not when the car was in motion. Maybe the laser is THAT sensitive. Hope this works for you.
Jun 29, 2009 | 2002 Nissan Sentra
Err message appears when CD function is used
check this link for service manual
Don't forget to rate the solution
Jan 09, 2009 | Emerson ES30 Shelf System
Cd player takes cd the releases with ERR showing on the display
open cd player.clean lens with cotten.your problem will be solved forever.had same problem.
Jul 15, 2008 | 2001 Nissan Sentra
Tascam Mixwell - CD-DJ1
on putting in the cd and shutting the lid an error occurs. on the screen it reads' remain err sled' and the cd is not spinning. what is the problem???
Dec 29, 2007 | Audio Players & Recorders
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
Sharp SC-9650 Shelf System Logo
61 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
