Question about Garden
Changed the primer blub now it wont start - Garden
  • 731 Answers
If the bulb needed to be replaced more than likely the fuel lines are in need of replacement. You may have damaged one as they be come brittle with age and can crack or break easily
Posted on Apr 01, 2016
Can't get primer blub to pump gas
The primer bulb may have a pinhole or be worn out. Also check the primer line going from the bulb to the carb, could be pinched, blocked, or the attached ends may be too loose. Try pulling the hose ends off, it should not be too easy to remove them, if it is and its long enough cut off the old loose section and reinstall.
Nov 09, 2014 | Troy-Bilt Tb320bv 31cc 2-cycle Gas Powered...
Lawn mower starts, then stops
Most likely the carburetor will need to be cleaned and replacement of the needle valve and bowl gasket. If it has a primer blub you might check to make sure it is not defective. Hope this will help.
Jul 19, 2014 | Toro Garden
Primer bulb removal on a 1994 vantage 35 mower how do you remove the bulb
most lawn mower primer blubs have a metal ring holding the base in. Just uses use a small screw drive or hook and drag in out.
Feb 04, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Gas is pouring out of primer bulb, Dancel in distress.
Sometimes the screws around the blub come loose, tighten
them. Or may a crack in primer bulb.
Sep 10, 2012 | Toro Power Lawn Mower
Need to replace a primer blub on a tb70ss
contact Troy or Google the model number to see if you can find a service manual for this model.
Jun 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
Won't start, appears to be getting gas, primer bulb full.
HELLO. DO YOU HAVE THE USER'S MANUL.? IF NOT HERE IS WHAT YOU CAN TRY.(1) FIRST . TAKE OFF THE AIR CLEANER. AND CLEAN THE FILTER.. USE A LITTLE DISH SOAP LIKE DAMW.DISHSOAP AND WATER. ONLY. WASH & RINCE OUT.! THEN DRY IT OUT. (2) THING TO DO IS PULL THE SPARK PLUG OUT. AND REPLACE WITH THE SAME AS WHAT IT IS IN IT. (3) OR U CAN CLEAN IT WITH A TOOTH BRUSH & A LITTLE GAS ON IT. OR STARTING FLUID ON THE BRUSH .CLEAN IT THEN LET IT DRY OUT. AFTER THEY ARE DRY. (4) PULL ON STARTING ROPE WITH OUT THE PLUG IN IT. 3- 4 TIME'S . THEN (5) WITH THE AIR CLEANER OFF & THE CHOKE OPEN. LOOK IN THE CARBURATOR AND PUSH THE PRIMER BLUB. TO SEE IF IT IS GETTING TO THE CARB.? YOU SHOULD SEE IT OR HEAR IT OR SMELL IT.? IF THERE IS TO MUCH.&. IF THERE IS.! THEN PULL THE STARTING ROPE AGAN 3 TIME'S . (6) THEN PUT A VERRY SMALL AMOUNT OF GAS IN THE PLUG HOLE AND PUT THE SPARK PLUG BACK IN. & WITH THE AIR CLEANER OFF PUT THE CHOKE TO THE STARTSPOT.. PRIME IT 2-3 TIME'S WITH YOUR PRIMER BLUB AND TRY TO START. IT. IF NOT (7) PULL THE PLUG OUT AGAIN , AND PULL THE ROPE AGAIN 3 TIME'S . (8) THEN GET STARTING FLUID AND SQUIRT SOME IN THE PLUG HOLE & PUT THE PLUG BACK IN. ..THEN SQUIRT A LITTLE IN THE CARB & TRY TO START IT . IT SHOULD WORK. . IF YOU DO THE SOLUTION'S FOR THE PROBLEM YOU ARE HAVING THANK YOU . REMBER TO VOTE FOR ME THANK U.?
Jun 08, 2011 | Mantis 2-Cycle Tiller
I've lost my primer plunger from my Toro ccr2450. how do you replace it?
Any local parts supply will sell yo the primer blub. they are very common.
Best of it Gary @ Fix Ya
Jan 12, 2011 | Toro Lawn Mower With Toro Power Tools
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
