Question about GE G.e. Gtwn4950lws He Top Load Washer
Washer will not high spin
Will spin slow but not fast
  • GE Master
  • 2,992 Answers
I couldn't do any better than above!
Posted on May 25, 2015
  • GE Master
  • 5,323 Answers
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
Washer will not high spin - washer-will-not-high-spin-3gtroy05deocb4x2c1cgsv5x-3-0.jpg
Washer will not high spin - washer-will-not-high-spin-3gtroy05deocb4x2c1cgsv5x-3-14.jpgot-high-spin-3gtroy05deocb4x2c1cgsv5x-3-14.jpg" alt="washer-will-not-high-spin-3gtroy05deocb4x2c1cgsv5x-3-14.jpg" class="h_mi" />
Posted on May 15, 2015
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: clothes are clean but soaked. Very slow spin
Clean out the drain pump AND connecting hoses.
Posted on Aug 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: i have a ge top load washer model wbse3 120b on
The motor reverses rotation to spin. Your motor is going bad.
Posted on Jan 24, 2010
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer spins but really really slow, not fast enough to extract water
it can be the pump if it does not get the water out fast it will slow spin best way to check put it on spin with nothing in and watch it if it does the same then the moter is faulty change it try ebay for replacements
Jul 28, 2009 | Speed Queen ATS90AWN Front Load Washer
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
GE G.e. Gtwn4950lws He Top Load Washer Logo
145 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
