Question about Hotpoint Hot Point HTDX100EMWW Electric Dryers
Why is the outside top so hot to touch. It is 2 weeks old and Vents were cleaned before using.
  • Hotpoint Master
  • 5,323 Answers
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Posted on May 04, 2015
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
The pump gets rid of the water in the pan but leaves paper and other deposits behind. I cleaned out the pan but the problem still remains and after about 2 weeks it needs to be cleaned/emptied again. No...
Check the vent pipe, air must flow in and out of the vent pipe at all times. The vent pipe must be an 1 1/2" pipe coming off the top of the pump casing and vented outside the house, to the open air. Do not use a cheater vent, studdor vent or mechanical vents as they are not recommended to be used, they only allow air to flow one way.
Feb 28, 2013 | Saniflo & Saniplus& Macerator Pump
First off the dryer is over 20 years old. Recently about a month now it has been heating too hot. The clothes that come out are too hot to touch for at least 5 or 10 minutes. We checked all the vents and...
Sounds like there is a faulty thermostat, or the programmer is not going into the cool down cycle, if it is 20 years old, then I do not think it warrants a repair, you will probably not be able to get the spares for it, my advice is to buy a new one.
Nov 29, 2010 | Dryers
Inspiron 1521 is running hot
I recommend you check your air vents for dust buildup. Use an old toothbrush to clean the dust off the outside of the vents and then use one of those cans of compressed air meant for cleaning keyboards to blow air through the vents to dislodge any dust accumulated inside. Some laptops have more than one vent. Make sure to clean all of them. I once worked on a Sony laptop that I had to take apart to clean out all of the vents.
Jun 30, 2009 | Dell Inspiron 1521 Notebook
Natural gas dryer running too hot
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
RANCID BUTTER melted in Bunn Thermofresh resevoir vents!
There is one thing you can try first. With the machine filled with water and turned on, pour in 1 quart of white vinegar and let it sit in there for 2 hours. Then flush it back out with 8-10 carafes of water. If this doesn't correct the problem, then call customer service with the model and code date. This can be replaced under the warranty if it is under 3 years old or less. If it is over 3 years old, it can be replaced at a reduced price.
Jan 12, 2009 | Bunn NHB Coffee Maker
Very Hot Top
It appears that your venting system is restrictive to a point that the hot air coming from the exhaust of the dryer cannot get outside due to excessive lint in the line. If possible, can you use a flex line and temporarily vent it out thru a window until your hard-piped vent dries out and can be cleaned properly? These dryers have thermal overloads to shut them down if they get too hot but since you mentioned the heat was near the top in the back.. I would make sure the power cord connections are tight.. ( do this by unplugging the dryer from the wall receptacle) the open the access cover were the cord enters the back of the drier.. then use a screwdriver and and make sure all 3 or 4 wire terminals are tight. A poor or loose contact there is resistive and may get hot enough to cause a fire. Make sure to remove or disable power BEFORE servicing this area.. Hope this helps..
Aug 31, 2008 | LG DLE9577 Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Hotpoint Hot Point HTDX100EMWW Electric Dryers Logo
89 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
