Question about Kenmore Elite C970 440935
What does a code 14 mean?
Try to turn on the oven and get a code f14 on the screen and the oven will not turn on
Kenwood model 790.47849408. How can I correct recurrent F14 error?
(F14) Misconnected flat cables have you replaced the board?
Try this solution Disconnect power; verify flat cable connections (P6 or P12)
Feb 03, 2016 | Ovens
What code does F.14 mean
F14 indicates a failure with misconnected keyboard cable.
Oct 10, 2014 | Ovens
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
What does it mean when the oven beep and F10 is on the screen
Go online and type in your model number and ask what the F10 code means. Every stove is slightly different. Mine did the same thing and the F2 code came on. Meant the sensor was gone and I replaced it in 10 minutes for under $80. Even a novice can do it. Perhaps same with yours, perhaps not.
Jan 08, 2010 | Kenmore 33169 Gas Single Oven
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Jan 11, 2009 | Gaggenau EB270 Electric Single Oven
Installed a new electric wall oven and have power as the clock was able to be set and it works. When I push bake I get an F14 error message instead of the -----lines that I should have. It also has an...
I called the place where we bought the oven and after 1 toll free call with many options to go through and talking to three different women I was able to talk to a repair person who ended up being 25 miles away! Since this was on a Saturday he came out today and all it was was a loose wire!! Thanks for getting back to me. Lorelee
Apr 20, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
F 14 Error Message
well first it doesn't matter when the problem occurred warranty is warranty but you can pull the oven out and pull the panel off the top where the eoc is and pull the mylar ribbon out there is a black plastic piece at the base of the ribbon pull it up and pull the ribbon out clean it with a pencil eraser then reseat it and lock it down if that doesn't fix it then the eoc must be replaced go to www.frigidaire.com and find a service in your area it will be a warranty issue
Feb 09, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Code F14
F14 is usually the fault code (open circuit) for the NTC sensor on the electronics module. I would suspect a bad connection from the oven temp sensor (located at the rear of the oven) to the electronics module. If you are able to remove the oven from the enclosure and remove the top and rear panels, (power disconnected!!) I would suggest checking all connections to/from electronics module. Also make sure door contact switches are secure and not loose (remove side panels) Oshie
Mar 22, 2007 | Gaggenau EB294/295 Electric Double Oven
Kenmore Elite C970 440935 Logo
59 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
