Question about Saturn 2002 L-Series L100
2002 saturn L100 code p0140 air injection malfunction fix?
    Top Expert:
  • Saturn Master
  • 1,144 Answers
Passenger power window not working on 2002 Saturn L100. Fuse OK, so is relay. Anything I am missing?
Hi Lance
Just a process of elimination
Run a power lead from Battery directly to motor & test.
Cable to motor may be broken internally from flexing at door joint?
Good Luck
Sep 21, 2015 | Saturn 2002 L-Series L100
Code P0412 shows on my 2007 Ion Saturn car. How do I fix it?
code p0412 refers to secondary air injection (AIR) solenoid A---circuit malfunction===causes wiring---air solenoid---ECM
replace the AIR solenoid.
Mar 13, 2015 | 2007 Saturn Ion
Diagnosis read fault p336
p0140 - 02 sensor circuit no activity detected, (bank 2 sensor 1)
P0170 - fuel trim malfunction (bank 1) MM6LP - fuel injection fault
P0336 - Crankshaft Position Sensor A Circuit range/performance SID801/4 - Engine speed signal coherence.
P0352 - Ignition coil B Primary/secondary circuit malfunction MM6LP - 2/3 ignition coil control. Open circuit, short circuit to positive, short circuit to earth. ME746 - NO.1 Ignition coil control function. Short circuit to earth. ME746 - NO.2 ign. coil control function. Short circuit to earth.
P0414 - Secondary Air Inj. system switching valve A circuit shorted. MM6LP - Air pump relay control failure.
Mar 21, 2014 | 2008 Peugeot 307cc 1.6
P0410 code for 2002 Saturn L100. What is a secondary air injection system?
secondary air injection pump go on youtube they have vedeos on how to troubleshoot and repair
Oct 21, 2013 | Cars & Trucks
Saturn SLI trouble code P0410
P0410 is Secondary Air Injection System Malfunction.
Jun 17, 2012 | 2002 Saturn S-Series
I have a 2002 GMC Sierra 1500. 4.3 liter engine. I brought it to autozone and they put the gauge on it and got two codes P0140 and P0300. I had my distributor cap replaced, ignition rotor, plugs ,wires,...
Clean mass air flow sensor with a nonchlronated brake cleaner,install new air filter and check all vacuum lines for leaks then check for vacuum leak around or at intake manifold.Code P0140 is for mass air flow sensor code P0300 is a multiple misfire which more than likely is a vacuum leak possibly intake manifold gaskets leaking.
Apr 11, 2011 | 2002 GMC Sierra 1500
OBD Code P0410, Secondary Air Injection System. What do I repair?
Usual causes are air in air pump, solenoid malfunction, the secondary air check valve, or loss of power to pump solenoid. Pinched, loose, cracked, or broken hoses can also cause this code.
Oct 18, 2010 | 2000 Saturn SL
Engine light code P0410
a po410 code is, Secondary Air Injection System Malfunction.
Jan 30, 2010 | Saturn SL1 Cars & Trucks
Saturn 2002 L-Series L100 Logo
61 people viewed this question
Top Saturn Heating & Cooling Experts
Tom Chichester
Hank Orsel
Level 1 Expert
David Ellis Rhea
Are you a Saturn Heating and Cooling Expert? Answer questions, earn points and help others
