Question about Hitachi L46S603 TV
Dark picture will not get brighter can I fix it
Picture has gone very dark will not adjust brighter
Could be your backlights are bad. Don't know how old your set is. May check your backlight setting up and down to see if it changes the brightness. Not a cheap fix at repair shop. You can order online and change yourself with the help of you tube videos.
Aug 02, 2017 | Televison & Video
My husband pulls tractors at night at tractor pulls, everytime I try to get a picture its too dark, the lighting around the pull isn't the greatest but it has some light
There are several solutions to taking pictures in the dark or low light. Night time photography can be difficult without a tripod. There are three ways you can get a brighter photo
1. Larger aperture - Make sure the aperture is set to the lowest f-stop for the largest aperture. f/2.8 or f/5.6 depending on your lenses capabilities. Choose the lowest number
2. Longer shutter speed - A longer shutter speed will allow more light to hit the canera's sensor and create a brighter picture. Unfortunately with a longer shutter speed, you will probably need a tripod because the photo will come out motion-blurred otherwise.
3. Higher ISO - A higher ISO will make the camera's sensor more sensitive to light and therefore creating a brighter picture without having to have a longer shutter speed. High ISO, however, can introduce unpleasant noise/grain to a photo.
If you want to take your picture while holding the camera in your hands, I recommend the largest aperture (small f/stop) and a high ISO.
If you have a tripod, use it! and use a longer shutter speed since the tripod will hold the camera steady for you.
Jul 09, 2011 | Nikon Cameras
Why is my picture so dark on my 60" ? can't seem to make it brighter,
Check in your manual to is if it take a projector lamp? If the lamp is going bad the picture will start to get dark. Hope this is helpful.
Oct 22, 2009 | Hitachi Televison & Video
Philips HD Projection TV just too dark (No Luminance)
sounds like the coolant needs to be replaced in the CRts as that will give you a very dark and dull colored picture. The phillips CRT coolant replacement kit at the following link contains the coolant and the CD with instructions.
http://www.tvrepairworld.com/
Jul 22, 2009 | Televison & Video
Camera is dark
when i go to take a picture or a video it comes out dark. you can't hardly see the person i took the
picture too. It's very fustrating not knowing how to fix the matter. all those buttons are not helpng at all. Can i get any suggestions on how i can make the pictures come out brighter?
Nov 06, 2008 | DXG Technology DXG-305V Digital Camera
SONY KV-35S26 Blinking picture
Guess I should have looked throught the next couple of posts... The problem you have there you will not be able to repair yourself but a good shop can fix it temporarily. The CRT (Cathode Ray Tube) or picture tube is shorted, that's what is causing your blinking. You can call around and ask a shop locally if they can rejuvenate it for you using a crt analyser. In the shop here we use a BK467 which would fix the problem for awhile. What they will do is take the back off and hook-up the analyser and remove the short temporarily. That fix could last weeks or even months, in most cases though never more than a year. Turn the RV1791 back down, it has nothing to do with the G2 voltage and you don't want to overdrive the crt anyway. Take it back down until the horz. lines disappear in dark scenes or background. Then take it in and have the picture tube rejuvenated. Then start shopping for a new Tv... You'll need one eventually but this will buy you a little more time.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 02, 2008 | Televison & Video
Picture is dark
Pull the back off and tap on the deflection board. Does it get brighter? If so, you have a bad connection and or cold solder joint.
Dec 07, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi L46S603 TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
