Question about Building Materials
Guardian garage door open will not close, it beeps 12 times
    Habit-Forming:
  • 31 Answers
Does your garage door budge at all when you try to close it? Last month, my garage wouldn't close, but it would act like it was going to by moving a few inches and then closing again. If that's your issue, then it's probably just the sensor and it should take a simple repair job. http://www.allamerican-garagedoor.com/residential-garage-door/4589758099
Posted on Jan 27, 2016
  • 2,210 Answers
Optic sensor issue most likely. check alignment, check wire for breaks, check staples shorting out wires. it you hold the wired wall button and the door closes, then it is a sensor issue. you can also just jump the terminals where the wires connect on the opener motor and see if it works normally, if so, again the sensors are the issue.
Posted on May 01, 2015
  • Zach Thalman
    Zach Thalman May 07, 2015
    I don't have this kind of garage door, but I know my light will flicker if there is something in the way of the sensor. Generally if there is something in the way of the sensor, it will not allow the garage door to close. I would make sure that there isn't anything in the way before you jump to change out the terminals. http://www.dsidoorservices.com
  • rdjagger May 07, 2015
    Didn't say to change out anything. Said run a wire between the terminals. "Jump" them. A quick easy test.
My craftsman garage door opener is beeping (2 hours). How can I stop it
Our garage door opener has a safety beam across the floor which prevents the door from closing on objects which are sitting there. This safety feature also makes an annoying beeping sound each time the beam is crossed. This tutorial will show you how to disable the beep, but still keep beam functional. https://www.youtube.com/watch?v=Cn_vGe_7_x4
Jul 14, 2016 | Sears Craftsman LiftMaster Chamberlain...
Guardian garage door problem
check for loose or out of adjustment limit switches for the door travel
Jun 05, 2016 | Building Materials
Guardian sectional door 21230L opens & closes by itself without any one touching the remotes.
check all the wiring and be sure it is not pierced by a nail or staple
Oct 15, 2014 | Building Materials
My Guardian 628 will not open or close.
Manufcaturer will likely have a problem solver on their website or you should be able to get a number to phone for advice etc
Oct 05, 2014 | Building Materials
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers Tom
I have the same problem. Door does not open or close when press the push button and/or transmitter. The light flashes 5 times. Manually open or close the door is ok. On the manual troubleshoot, it says it's either the opener is overheated or it's on vocation mode. I don't know how to switch of vocation mode. Is it possible the thermal sensor is broken?
Can someone help?
Jan 28, 2011 | liftmaster Electrical Supplies
Guardian garage door opener not working,when I press the remote handheld button,the light in motor unit starts flickering. untill I press one of the 4 small switches,then it stops flickering. garage door...
Is your door jammed or could the door be moved smoothly? If not then the motor might not be able to start and it flickers, try to press "+" for open or close (depends on whether the unit is going to close or open the door) once at a time and try to remote it, this will increase the open/close force and may overcome the issue.One more thing, do the photo-eye sensors give unobstructed with good indication?
Jan 20, 2011 | Kitchen Ranges
Garage opener only travels about 12"
Sounds like something is binding causing the safety feature to activate the same as if it hit something. Bring the motor down to the point where this happens and pull the plug. At this point turn the motor manually and attempt to find the obstruction. You can also confirm this by changing the sensitivity so as to almost cancel it. Don't leave it that way, the safety feature is to protect anything it might hit as well as the opener itself. Do this only for diagnostics only and be ready to kill the power.
Oct 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
1,510 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
