Question about Epson Lq-690 24 Pin Dot Matrix Printer
Hi just go a lq690 and perforation on pre printed paper wont reach the cutter so very hard to cut the paper. any solutions please
  • 63 Answers
When you are printing select proper paper size.
Posted on May 09, 2015
What is a rotary paper cutter?
This is a cutter with a wheel-like blade that comes on a rail you can slide along. This lets you make cuts that are wavy or perforations. These are usually used at home becuase they are safer as the blade is wheel-like and not like a knife.
Jan 17, 2013 | Office Equipment & Supplies
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
In the paper and quality options I have only sheet or CD/DVD to select from. Roll option is not showing
The Roll Paper button cuts, feeds and returns paper to the printing position when the automatic cutter is used. When held down for three seconds, it reverses the roll paper out of the printer. The cutter can make either one cut precisely between images, two cuts with a margin between images or no cuts. The driver lets you select which method you prefer. The Utility program has an alignment option for the cutter that you should use whenever you reinstall the cutter.
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 17, 2010 | Epson Stylus Photo 1400 Printer
Grinding noise when printing and cuts paper
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Perforations on paper
I can't find anywhere on Canon's information that it has the ability to perforate as a setting.
This sounds like that is something dragging from the print head that is causing it.
I would take it back to the shop you got it from, and have them replace it.
Make sure to take an example of what it is doing when it prints.
Jul 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
HP DesignJet 110 - will not move cutter after job is printed
for paper cut, you should see the printer properties, there you can fine Auto Cut paper Check box or some thing like that. Make the correct setting, then it will work.
Thanks & Good Luck
Iqbal
Jun 10, 2008 | HP Designjet 110plus nr InkJet Printer
Using the cutter
you want to print borderless on a cutsheet media? you just have to select and 'cheat' the printer in the printer properties, in there choose roll on the paper source option then enable the cutter and choose double cut on printer's set-up menu on the panel, then it'll cut before and after the printing to make it borderless from top to bottom and from edge to edge. just be sure that the cutsheet media is long enough so that the printer can still hold the media as it finishes the printing or else it'll be a waste, cause the printer wont finish the image. and take note that the epson sp9600 has a limitation in printing borderless, it'll only print borderless on (12", 17", 24", 36:, and 44") media size only i think there's also 14". trust me it'll work, ive done it! :P
Sep 26, 2007 | Epson Stylus Pro 9600 InkJet Printer
Perforation when I print
My dell 924 all in one is doing that very thing and I cannot figure it out either. I called it scoring, but perforating is a better explanation for it. If you ever find a solution or clue, please advise at paynehouse@cox.net, subject dell 924 perforation. Thanks so much...and gl
Apr 02, 2007 | Dell 924 All-in-One InkJet Printer
Epson Lq-690 24 Pin Dot Matrix Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
