Question about Maytag Dryers
My maytag bravos dryer says AF and I cleaned the filter what else could be clogged up?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 173 Answers
Check vent tube in back of dryer an also check the outside vent make sure you have a good air flow
Posted on May 03, 2015
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
SOURCE: AF light comes on
It means "Air Flow" there is lint caught in your vents. You will need to vaccum them out.
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
mkh5094
  • 145 Answers
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
Posted on May 02, 2010
I have a Maytag Bravo dryer. While it dries, it stops by itself turning. All the lights on the dryer stays on, but the dryer wont turn on unless I wait a good 30 minutes, and then try again. The lint...
Sounds as if you have a clog somewhere. This is designed to stop running when it senses there is a back flow or resistance to the air pushing through here.
Jan 25, 2015 | Maytag Bravos Series MEDB850YG
Dryer won't stop on sensor cycle
Check for clogged or kinked vent line and then after that it could be the blower wheel. But need a model to answer more precisely
Sep 26, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos gas dryer exhaust belt came off
Probably because the exhaust ducting is clogged. A common problem on these.
Pop the top just like the old models and remove the front then the shroud and then clean her up.
Nov 06, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
What does af mean on the dryer screen
af ,stands for air flow could be a kinked exhaust vent hose, or a restricted or cloged exhaust duct going outside.
Aug 05, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
AF Error Code
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
AF On Dryer
I went to Lowe's where I bought the washer and dryer and asked them about it. They told me what to do
May 11, 2009 | Maytag Bravos MTW6600T Top Load Washer
Apr 23, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
AF light comes on
Mar 25, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryers Logo
95 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
