Question about Ricoh Aficio MP4500, MP3500 Kit
How to repair SC 322 code on Ricoh MP3500
Polygon motor and adjustments did not fix. Anything else besides the whole laser unit
  • Ricoh Master
  • 2,825 Answers
  • Ricoh Expert
  • 155 Answers
Try Reseating laser connectors. If that doesn't work laser unit
Posted on May 02, 2015
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
How to remove code sc 322
322 C 1st laser synchronization error
• The 1st laser synchronization signal
cannot be detected by the main scan
synchronization detector board even
if the laser diodes are activated.
• Poor cable connection between the
laser synchronization detector board
and the LD unit.
• Laser synchronization detector board
out of position and angle of reflection
not correct
defective
• LD unit defective
Most likley to be polygon mirrow thats faulty.It is inside the lazer unit.If u hear loud winding noise that will point to polygon mirror,or possibly it has seized up and cant turn at all.In any case ull need service engineer to replace it.
Dec 04, 2010 | Ricoh Aficio 1045 Black and White Copier
Codigo sc-322-000 copier ricoh aficio 450
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
Hope that helps!
Oct 22, 2010 | Ricoh Aficio 450 Copier
Can i reset the error code sc 320
sc 320 is the laser error. the polygon mirror motor is faulty in laser unit and it can only be solved by replacing the polygon mirror motor. there is no other solution.
Oct 12, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio AP 2600 laser printer there is a code SC-322
On most Ricoh models, SC-322 is a problem with the laser unit. If you have a service contract, have your technician take a look at the printer. Otherwise, you can either have a local Ricoh tech give you a repair estimate or buy a new printer.
On rare occasions you can turn the printer off and turn it back on and the code will be cleared, but most of the time this is a serious error that requires a service technician.
Apr 28, 2010 | Ricoh Aficio AP2600 Laser Printer
Ricoh Aficio MP 1600 Le error code sc 322 occured during print job how do i clear it
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Jan 12, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 250 code sc 320 polygon motor. How hard is it to change?
Hello sir; It is easy to replace it, the laser unit right under the toner unit remove the cover pull out laser unit the polygon motor right in there.
Sep 10, 2009 | Ricoh Aficio 250 Copier
Ricoh 1035 laser problem
sometimes the plastic of the laser is turned by the heat proves to relax and to fit the screw that holds the laser unit that is of the side of the drum while it raises a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well be positioned correctly.
Other
Poor connection between the laser
synchronization detector board and
the LD unit.
out of position
defective
LD unit defective
May 07, 2009 | Ricoh Aficio 1035 Copier
Leazer
I don't have the specifics for that service code but all the other Ricoh copiers that have an SC3XX in the code indicates the polygon motors aren't working properly.
Check the cables out. Make sure your firmware has been upgraded as well.
Aug 20, 2008 | Ricoh Aficio 450 Copier
Aficio 450
SC 322 is a laser diode problem. It will require service.
Mar 27, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio MP4500, MP3500 Kit Logo
425 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
