Question about Garden
How do you change transmission fluid for simplicity mower with transmission part no 1729589
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
You probably cant! Most small transmission systems are sealed.
Posted on May 04, 2015
Simplicity 12.5 LTG transmission will not engage
Then likely it needs to be rebuilt.
Apr 25, 2017 | Cars & Trucks
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
Finally decided to follow the manual's recommendation and changed the transmission fluid (SAE 10-W-30) while doing an end of season overhaul. Engine runs fine, but no forward or reverse. Over the last...
Did you loose forward and reverse right after fluid change or was it gradual? Sounds like you have air in the system. I would jack up back end and leave fluid fill cap off overnight. Maybe lay a light rag over it to keep debris out, but with the cap off and back end jacked up it should help air bubbles find there way out. Then, replace cap, leave jacked up and try bleeding by forward and reverse. Hope this helps.
Oct 19, 2013 | Garden
Mower deck slows and stops when I turn my Simplicity riding mower to the left,
HI,
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
Aug 25, 2012 | Garden
I have a hydro gear transmission i have changed oil and when it gets hot it will not move it is a simplicity rider 2000 mod.i need help please my email is wunrau@mymts.net thank you kindy
Your transmission is shot. You need to buy a new or used one and install it. Or there may be a rebuild facility which will rebuild yours. Either way it will not be cheap.
Aug 12, 2010 | Garden
My simplicity Coronet Hydro 13 lawn tractor loses power in the transition after about 20 minute run time. It has a sealed Hydro Gear box. Any suggestions to make it run better? It has a 30" Deck and a...
The fluid in the transmission is a multigrade oil. sometimes you can change the oil by removing the transmission partially or entirely and change the oil to a heavier grade like 15W40 or 20W50, the transmission has a vent mechanism on top that is where the oil would be extracted or drained from and then refilled, the level at full cold is 1" to 1 1/4" below the bottom edge of the inside of the vent pipe or plug boss. some of these had a flat vent plug, some have a hose with the vent in the end attached at a nipple and still some older units had a reservoir like on the larger tractors. The reason your trans is slowing is due to wear in the hydraulic pump face.
Jun 04, 2010 | Garden
Soft steering 2007 Simplicity Prestige 27hp tractor.
have you checked your fluid level
Aug 13, 2009 | Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
