Question about Dyson DC33 Multi-Floor Upright Vacuum Cleaner
How to change belt on Dyson dc33
When running the vacuum the brush does not turn. Is it the belt or the gear?
  • Official Brand Answer
  • 2,572 Answers
Hi William, it's Jack at Dyson.
DC33 doesn't use a traditional, user-replaceable belt. Instead, the two belts are part of the brush control mechanism, which allows you to shut off the brush bar to clean hard floors and delicate rugs. These belts are engineered to last the lifetime of the machine in normal use.
If your DC33's brush bar isn't currently rotating, please follow each of the steps shown in our online Support guide, to rule out any simple issues: http://www.dyson.com/support/dc33/dc33-multifloor/using-my-dyson-list/flo-dc07-gen-how-to-remove-a-blockage/redirect-to-removing-debris-from-the-brushbar-dc33/removing-debris-from-the-brushbar-dc33
It's also important to make sure your DC33's brush control is set to carpets rather than hard floors:
how to change belt on Dyson dc33 - change-belt-dyson-dc33-mnih3g4zkwkucv5j2ppnmw4z-5-0.jpg
If you still need help with your machine after trying these simple checks, you're welcome to get in touch directly. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on May 06, 2015
Hello, I have Dyson DC33. The brush bar isn't turning & the belt is on & intact. Any suggestions?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc33
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 18, 2016 | Dyson DC33 Bagged Upright Vacuum
The brushes on my dyson dc33 won't turn. I know the belt hasn't broke. Thanks SIMON
brushes on my dyson dc33 won't turn Simon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.dyson.co.uk/support/dc07/dc07-clic/my-machine-is-not-working/my-dyson-will-not-stand-upright/my-dyson-will-not-stand-upright/no1/yes1/brushbar-not-turning-clutch-check
How to repair Dyson DC07 DC14 DC33
Dyson Burning Smell Beater Bar Brush Stuck DC14 Not Working Easy Fix
Aug 02, 2016 | Dyson Vacuums
Brush bar does not turn when unit is turned on, belt is intact and no noticeable defects.
LOts of these units have a switch for brush or you have to pull back on the handle to start brush.
Hope this helps Mike
May 23, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
How do I change the belts on the Dyson DC33
Best would be to get a parts and service manual if you cannot do it without one
Dec 10, 2014 | Dyson DC33 Multi-Floor Upright Bagless...
Brush is not rotating
Hi Barbara, it's Jack at Dyson.
DC33's brush bar will only rotate when the vacuum cleaner is turned on and reclined into the normal vacuuming position, and the brush control is set to 'Carpets':
If the vacuum cleaner is standing upright, or set to 'hard floors', the brush bar will not rotate.
If you're confident the brush control is set correctly, but the brush bar won't rotate when the machine is turned on and reclined, please contact our experts directly so we can talk you through some further troubleshooting checks. If a repair is needed, we can also confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 08, 2014 | Dyson DC33 Multi-Floor Upright Bagless...
My Dyson DC33 isn't working correctly. It's not picking up like it used to. The brush isn't turning and the belt is fine. I've checked all filters, hoses and cleaned everything. Why is the brush not...
Is it possible that you have accidentally changed the brush control setting? I say this because it happened to me and I thought it had broken. I must have caught the dial with my foot! Here a link that might help:
Jul 09, 2014 | Dyson DC33 Bagged Upright Vacuum
I have a Dyson DC33 bagless vacuum and the beater brush is not turning .. How do I get the cover off the brush to change the belt?
If you lay it down so you can see the bottom of the vacuum, there should be 3 flathead looking screws,just turn them a quarter turn or so, and that bottom should pop off so you can take the brush out and change the belt, just make sure you watch how that brush comes out so you can get it back in correctly. Oh make sure its unplugged!!
Sep 13, 2012 | Dyson DC-33 MultiFloor Upright Vacuum...
How to change the belt on a dyson dc 33
With a small torx driver (not the folding kind, the screw driver kind) and some patience, the belts can be replaced pretty easily. They run about 10 bux for both (you may as well change both). Dyson, like most manufacturers, makes it seem difficult in the hopes that you'll send it back to them for repair, where they will most likely sell you the whole clutch assembly because its easier to replace than fiddling with belts.
Mar 17, 2011 | Dyson DC33 Bagged Upright Vacuum
Dyson DC33 Multi-Floor Upright Vacuum Cleaner Logo
398 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
