The sound is gone! What should I do^
Image is always good for each and every program. But the sound - even at 100 - is not there!
  • 26 Answers
If you have cable TV, check to make sure your sound is adjusted there. Could be one of the kids turned it down or something. If that isn't it,. look for dogs chewing wire from your set to the amp?
Posted on Apr 30, 2015
Cluster not working but the lamp is working
yes, your cluster has likely gone bad. you can pick one up cheap at the wreckers, but, all the programming is in the cluster.
if you have all the same options on your car, - traction control/stabilitrak you are in luck. Otherwise you will have errors which MIGHT be able to programmed the dealership for $100 but doesn't always work.
Jan 04, 2014 | 2007 Pontiac Montana
I did copied an image from a book so i want to make it bigger
You need photo editing software, like free Gimpshop.
Go to Gimpshop and download program:
This is a very good photo editor, and it's free.
http://www.gimpshop.com/
1) After the download, You have to open gimpshop once so a shortcut appears on desktop.
So go to start, all programs, and look for GIMPshop, and put mouse on GIMPshop, and box appears, and then click on GIMPshop located in that box.
Gimp opens. The close Gimp and see there is a desktop icon.
2) Find the image you want to make bigger.
Hover mouse over your image without clicking mouse, and the size of image will show in small box. For example it will show Dimensions: 1000 x 700
Write down the size
3) Drag and drop your image on top of gimp icon and program will open.
4) Once photo is loaded.
Go to 'Image' at top of program and select 'image size'
You will see numbers for width and height appear in small boxes.
Use your mouse and keyboard to change the numbers and double the size.
For example make new dimensions 2000 x 1400.
Or make it 3 times bigger.
Then click 'scale'
5) You will see the image is bigger.
6) Time to save larger image.
Go to 'File' at top of program
Click 'save a copy'
Box comes up with name. Re-name the image so it does not replace original.
Click save.
7) another box comes up with a 'quality' slider
Move slider to 100%
Click OK
8) Bigger image is saved and ready
Mar 05, 2011 | Cycling
ACER 3000 BATERRYSTARTS TO DRAIN DOWN FAST TO NOTHING IN A MATTERY OF 5- 10MNS AFTER BE 100% CHARED
Pam, The battery has gone. Needs a replacement. Even my Sony VAIO battery has gone but now I am using it as a desktop (always connected to the mains). Dont have the money to replace it.
Jun 04, 2010 | Acer Aspire 3000 Notebook
I have the same problem w/ my canon ixus 100IS.UNIDENTIFIED IMaGE
Try using a card reader to download your pics. Also, go to a store like Walmart that has a Kodak picture maker machine. You should be able to see all of your pics and print them or even make a cd of them.
Nov 14, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
All the images on my computer have converted from Photoshop programme to Quicktime. I can no longer use the applications in Photoshop. I have gone into tools and said open with photoshop but that does...
To resolve this issue right click on an image on your computer (preferably a photo), select "open with" from the sub menu. If Photoshop is in the list don't choose that, select choose default program instead.
A new window will pop up, if Photoshop is in the list of recommended programs highlight it and make sure the "always use the selected program to open this kind of file" box is checked (with a tick in it) and click OK. Photoshop should automatically open the image for you then and for the rest of your images.
If Photoshop is not in the list click on browse and navigate to local disk C\Program Files for the Photshop program, Click OK and you should be good to go.
Regards.
Sep 15, 2009 | Computers & Internet
SOUND PROBLEM
No way, you do not understand video software.
All sound and image have their codecs even raw.
Pinnacle is troublesome
Ulead is better
For free even VirtualDub does a good job.
Canon was rejected because of poor image quality twice by me.
In any good video software you can adjust that automaically capturing "codec" if enough installed i.e. K-Lite codec package
From your story i gather your PC is way below Pinnacle capacity (too heavy burden) so it cant process and compress fast enough resulting in frame and soundbits los. CPU, memory, diskcache etc all to be taken in consideration.
Apr 14, 2009 | Canon MVX330i Mini DV Digital Camcorder
Webcam
Ok im not sure what cam you have or comp that your using, but cahances are you need to go to your web cam settings:START/ALL PROGRAMS/ "your cam"/ CAM SETTING. there you should see inverted or mirror settings, it might even be in ADVANCED SETTINGS try and look for it, Good luck JLS
P.S. you could always turn your cam upside down! LOL Just kidding!
Sep 21, 2008 | Acer Aspire 5610-4648 Notebook
Set default photo viewer
Dear Susan, generally MS doc pics are copy paste images or they're embedded in the document through screen shots. If you click the image it would find the default image viewer and open it in it. If you want to remove this feature you might like to right click the image in MS word and remove the hyperlink feature if its from URL. You might also like to save picture by right-clicking it and using option save as...
I recommend not to click images in a document because it would always search for a default program to open it.
If that was helpful please press fixya.
Nov 28, 2007 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
